BX 2680 Throttle
/ BX 2680 Throttle #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
Just curious, anyone else have a throttle lever from **** on the new 80 series BX's?
I mean really, it should not be that hard to operate the throttle. Mine is so hard, I feel
like i'm going to break it off...
Thanks
Dave
/ BX 2680 Throttle #3
This is little bit old of a thread but I will comment on what recently happened to me. Mine worked its way loose and the bottom nut spun right off. Replaced it with a nylock nut, much easier to get tension you like without worry it will loosen itself. Not sure why they wouldn't do that in the first place.
/ BX 2680 Throttle #4
My 2370 has the same problem and I may try that too.
A few nuts on the hydraulic control linkages have been changed for the same reason after we experienced slow bucket problems, there were a couple that had come loose, nylocks fix a lot of problems.
/ BX 2680 Throttle #5
Any chance you remember the thread size? I don't have any metric nylocks lying around, so I'll need to buy one.
/ BX 2680 Throttle #6
M8, Standard thread pitch (if its not labeled with a pitch then its standard, if it has a label I think 1.25 is considered standard.) I got mine at a local hardware store.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63118)
Neckover GL24-2-7K...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2018 Ram 1500 Reefer Meal Delivery Truck (A61568)
2018 Ram 1500...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
ASSET DESCRIPTIONS & CONDITION (A59910)
ASSET DESCRIPTIONS...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
