Buying Used Rotary Mower
/ Buying Used Rotary Mower
It is an SQ600. The manual lists the gearbox as 55 hp as you said Zebrafive. At the same time it states for "recommended tractor hp 25 - 40. Don't really know why the difference. Perhaps the PTO shaft or other parts are not rated as high??? Glad you pointed the 55 hp gearbox out, I feel better about that.
That was a fair price to start with. You got a good deal. Shear pins on a high HP tractor can be problematic. Make sure you keep throttle low when you engage the PTO.
I have been experimenting with that. If the rpms are up at all it really clunks in when engaged. Even with the rpms at the minimum, probably 1000+ (would need to look) it still clunks in but not as hard. Helps if I turn the knob slowly to engage but still not smooth. Is this normal???
/ Buying Used Rotary Mower #43
Not familiar with your tractor model. If turning a knob engages PTO it's probably doing it electronically and nothing you do can soften the shock load beyond doing it at idle rpm.
/ Buying Used Rotary Mower #44
Some tractors have a soft start PTO.
Gearboxes HP: Although a gearbox could be rated for 55HP, if there’s a weaker ā€œlink in the chainā€, that can knock down the maximum input HP.
I would probably want my gearbox to be rated higher than my PTO shaft. That way if there’s a failure, the shaft is probably a cheaper repair than gearbox.
Start/stop: I am running a 135HP tractor into a rotary cutter with 200+HP gearboxes. I always start at low rpm, then increase throttle to reduce shock load on my PTO, PTO shafts and gearboxes.
Also, throttle down your tractor before you shut off the PTO (unless it’s an emergency shut down) to reduce excessive wear.
Blades: the blades should be straight (no chunks missing) but not overly sharp. You want your lawn mower blades really sharp, but that’s because you want the tips of the grass blades healthy. ā€œRaggedā€ grass tips are more subject to disease. Bush hog tips are fine if they leave a somewhat ragged cut, because it helps kill the brush.
Checked from underneath. There is a little play when turning the blades. That might be the cause of the clunking.
/ Buying Used Rotary Mower #46
Hay Dude, where would the extra wear be when shutting down PTO at high RPM’s?
thx
/ Buying Used Rotary Mower #47
Jethro B,
PTO clutch brakes wear out faster when you shut off a bush hog at a high speed than if you throttle down against the engine to a lower speed, then shut off the PTO.
ā€Kubota Tractor PTO Problems Tip: This problem occurs when a bush hog, for instance, is shut off when the power is cut from the PTO. The blades continue to turn because of their weight. It should be noted that when the PTO is off, its clutch is disengaged. However, its brake is still engaged. The brake plate tab and PTO clutch holder suffer wear. *The implement should be turned off at idle speed only.*ā€
full article: Kubota Tractor PTO Problems - How to Engage PTO | Bobby Ford Kubota
/ Buying Used Rotary Mower #48
$500 is a good price. I paid $800 for a very beat up BH26: six footers are harder to locate in my area.
Try the blades as-is to see how they do: it can be instructive. For live brush it's better to have semi-dull blades as that fractures the brush and causes more stress: the aim is to kill the brush.
As noted, engage your PTO at low tractor RPM (I always look to raise the mower a bit before starting). You may feel a bit of wobble until things balance out: blades can start out folded up.
I'd recommend checking that the stump jumper assembly is tight on the shaft: raise the mower and with everything off and nothing moving, rock the stump jumper up and down- if it can move up and down then it may be tightened. I had the stump jumper assembly on my BH26 come off: interesting to say the least: might not have happened if I'd have checked for play and tightened (though I had to double up on the washers in order to get it tight enough on the shaft- tapered shaft and things wear a bit- best to catch before the splines get chewed up!).
/ Buying Used Rotary Mower #49
Yes. Getting those big blades spinning takes a lot of work. Doing that when the egine RPM's are at 540 PTO rating makes the blades want to go from zero to 100 like that. Lower engine RPM they are going from zero to 40. Then ramp up the engine RPM.
/ Buying Used Rotary Mower #50
Since you guys are all talking about his new(to him) mower deck, I have a question.
Do newer mower decks spin the blades faster than the older ones?
Yeah, I know the RPM of the tractor spins the PTO at that speed, but the newer ones might have gearing inside that turns the blades even faster??
The newer Zero turn mowers has a faster blade speed than older ones, and the same is true for push mowers.
/ Buying Used Rotary Mower #51
If the Bush Hog is pretty old would parts still be available?
All you need is bearings and seals. Get them at a bearing store. If you keep grease in it, don't need gears. Check for slack in drive shaft. A little is just fine. I prefer ones that are 2:1 ratio.
Roustabout, I do not know what you are referring to regarding the 2:1 ratio. Are you still talking about slack?
/ Buying Used Rotary Mower #53
Blade speed is measured at the tip of the spinning blade. I believe it's measure in feet per minute. Stated in thousands of feet per minute. This is very valuable information and can determine the fastest effective ground speed of the implement. The tip of the blade has to be able to come back around and cut the product before forward ground speed leaves a gap in the cut. The mathematically advantaged folks among us can explain that much better than I. :)
/ Buying Used Rotary Mower #54
Good question. I don't know what he is referring to either?
Looks like we may never know..... šŸ˜„
/ Buying Used Rotary Mower #56
Owner is asking $500. Does that sound reasonable?
Checked and gear box parts are still available for it.
I bought my bush hog in 1976 when my father died to keep the old farm cleaned up. I used it until 4 years ago mowing 20 to 40 acres a year depending on the year. Used hard. I also did some neighbours...bad idea. I hit rocks, old wood piles, even old car engines! Never do others properties as they never know what is there buried in the bushes.
My gear box was leaking bad when I used it 4 years ago so put it for sale for 500 dollars. A guy came right away and I sold it for $450. He said he could fix it no problem.
So my opinion is these old machines are tough and worth it.
I even regretted selling it.
Seems like it is pretty common around here for people to regret selling their implements and sometimes their tractors. Guess it seems like a good idea at the time. When we bought our first tractor, an older a Kioti LK3054, it came with a 5' brush cutter. We sold it because we had no need for it. Now, some years later found out I needed one and bought the one shown in the photos here. It is older than the one we sold but clearly heavier duty.
/ Buying Used Rotary Mower #58
I gave $600 for a 6' Rhino ten years ago. I haven't used it for two years. Sits in the corner of the machine shed. I'll not sell it. Soon as I do I'd have a need for it. :)
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
8' DISC HARROW (A60430)
8' DISC HARROW...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
UNUSED ZJG ZJ-13 EXCAVATOR (A60430)
UNUSED ZJG ZJ-13...
