Buying Used Rotary Mower
/ Buying Used Rotary Mower
Doesn't look like it has been abused and in pretty good shape. Check the gearbox oil and for signs of leakage underneath on the output shaft. Note: it is common in some areas of the country to remedy leaking seals with bearing grease. Check that the blades rotate freely and are not bent and are even. Check for play in the U-joints . Also noticed that it appears to be set up for a quick-hitch, in that the top link connector is missing.
Yes, it is not set up to attach the top link direct. I noticed it from the picture as well and the seller let me know before I went out so I brought my quick hitch which actually fit perfectly.
/ Buying Used Rotary Mower #22
Usually there is a port for max fill level. Or just half full. That's good enough. I would change it for some fresh 80/90.
Blades don't have to be sharp. But if you feel like keeping them that way, work is easier and you get a nicer job.
In a way, the way I look at stuff like this. You got this for FREE! You can use it, enjoy it and get every penny out of it (if not more) when you sell it. Well done!
/ Buying Used Rotary Mower #23
You can always get bearings you may have to cross reference them
and usually bearing shops have cross reference books.
willy
/ Buying Used Rotary Mower #24
Might be a small plug in side of gear housing to remove for fill level.
Yup!
Effectively it is FREE!
/ Buying Used Rotary Mower #25
I know people who can get good stuff for nothing. They would get that mower for $200.00 I don't know how they do it. I can't.
Yeah... and a lot of them are the same ones who never bought a stock or investment that lost money
/ Buying Used Rotary Mower #26
maybe half full or a few inches from the top?
willy
/ Buying Used Rotary Mower #27
I have met a few folks who tell stories like that.:)
/ Buying Used Rotary Mower #28
Actually, a friend of mine is like that. But on the other hand gets GREAT deals on tractors that never work when he needs them, spends all his time and a lot of money fixing them, then doesn't figure any of that in, sells them and thinks he did O.K. lol Then onto the NEXT "cheap tractor" looser project.
/ Buying Used Rotary Mower #29
With a little luck should provide many years of service.
Big fan of fresh lube...
Amazing how well a dull blade handles brush...
Can't tell how old this Bush Hog is but from search turns out that they must have made this model for many years. Was able to download an operations manual and parts manual. Happy surprise.
As you can see from the photo does not have a front chain guard. Am looking for purchase options.
Maybe call German Bilss Parts (an online Bush Hog supplier), and ask.
1-855-667-0970
Thanks Fried. Called German Bliss. Between model number and describing the gear box was able to find out that gear box parts are available.
/ Buying Used Rotary Mower #32
$500 is/was a GREAT price!!!!!!!!!!!!
It looks like it has a heavy deck, that's not all beat up.
Even if needed new blades, I would pay $500
Fill the gearbox to the center of the input shaft. A lot of guys use "corn head grease" if the seals leak.
Did you determine what model it is?
For your safety, buy the plastic PTO shields. If it has slip clutch, you might need new discs.
/ Buying Used Rotary Mower #33
Yes County Line is the low end of the spectrum..... however OP wnats to mow LESS THAN AN ACRE. If he is not abusing the thing by mowing down 3" trees all the time it will be fine.
/ Buying Used Rotary Mower #34
I have that same exact mower(5') and purchased new in 2004;I would guess it has 1K+ hours on it and still very good.Beat up more than that one.They have shear pins;had a gear box leak so filled with grease.Buy it.
/ Buying Used Rotary Mower #35
I bought a BH15 model (5ft) new in 2017 which I bet is the successor model to the OP’s purchase. Paid $1650 pre tax. Few model changes that I can see. Fine machine for medium duty. I would recommend front chains. The sun fades the paint pretty quickly. Good buy I think at $500.
/ Buying Used Rotary Mower #36
Congrats on the cutter. Hope it serves you well.
Is it wider than your tractor?
In regards to HP. The gear box will have a HP rating. That's it's maximum. Applying higher HP will increase risk of box failure. Usually appears in shaft shear. Better to have a 60hp box on a 45hp tractor than a 30hp box.
/ Buying Used Rotary Mower #37
You made a good choice. You’ll find it will cut brush just fine. Usually replace the blades and blade bolts at the same time. Enjoy.
Seller brought it over today. We hooked it up, ran it, and he gave me some pointers. I didn't negotiate the price because I had a nice connection with the sellers, liked them, and price felt fair. The thing is a beast. Everything is solid and heavy duty. Greased fittings today, will make sure everything is tight tomorrow, and hopefully get started on my project in a day or two. Been watching you tube videos for pointers.
Blades are definitely dull and may have them sharpened. Main reason is that there are as much as 10" of old oak leaves in places that I am hoping will mulch. Sharper blades seem like they may help.
I bought it knowing that my tractor HP would probably be rated high for it. Turns out that it is rated up to 40 HP and assuming they are referring to PTO HP, my tractor is about 4.6 HP over. Also my outer wheel width is about 66" and cutting width is 60". Was not my preference but well priced cutters don't come on the market often and it should work out fine for my needs.
I noticed that the new Bush Hogs are very red. This one is more faded pink. Expect it started out red as well. Definitely has been kept outside which is good since I won't have reservations about doing the same 😄
So grateful for all your assistance. Certainly helped a lot! Now the real education begins.......
/ Buying Used Rotary Mower #39
That was a fair price to start with. You got a good deal. Shear pins on a high HP tractor can be problematic. Make sure you keep throttle low when you engage the PTO.
/ Buying Used Rotary Mower #40
You have not posted what model it is.
I am guessing from the pictures it's a Bush Hog SQ600, which would have a 55HP gear box.
Good buy for $500.
I would probably just buy new blades and blade bolts and call it good.
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
Location Info Please
Luck Now 425 (A64126)
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
