Bush hog questions
   / Bush hog questions
After giving it the once over I found one of the steel rivets that held the Data tag, the other rivet has apparently rusted flush with the deck. It looks like it was mounted beside the gearbox and could have been read by standing to the left of the bush hog and facing the gearbox. WIN_20160708_175641 - Copy.JPG
   / Bush hog questions #12
r4 is the model number or something. I think it has to do with how heavy duty it is? My tag on my razorback it located on the truss support where the gearbox is mounted and it faces up. so not really the deck but that reinforced area of the deck I guess on the left hand side looking forward next to gear box.
   / Bush hog questions #13
just read all the posts and where you circled is exactly where mine is located
   / Bush hog questions #14
I think the Razorback is the standard duty and the squealer is more of a medium duty unit. The Squealer units have had a round back for about ten years so you have an older design. I don't know about this case, but sometimes older is better.
   / Bush hog questions #15
It looks exactly like my 18-year old Squealer, except it's missing the plastic guards over the gearbox and shaft.
   / Bush hog questions #16
We've got a 5' Squeeler just like it...
I've got to replace the front seal in the gearbox...
Little unit has run fine but it is not heavy duty...
I've beat the snot out of it...
The sides are gonna need reinforcement welded due to my abuse...
Don't use is much since I bought the Brown...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2005 John Deere 7420 (A60462)
2005 John Deere...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
294 (A52706)
294 (A52706)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56438)
Michelin CARGOXBIB...
