Rotary Cutter Bush hog crazy wheel....
/ Bush hog crazy wheel.... #21
No problem, I just put the diagrams vertical to make the cut angle more clear.
Aaron Z
/ Bush hog crazy wheel.... #22
The problem is he is trying to mow vertical 90 degrees uphill.
But you guys hit the nail on the head. Need that caster.
If it were mine though, as opposed to cutting it off and rewelding, I'd burn a 30 degree triangle out of each side strap leaving about 1/4" of strap left. Bend til triangle closes up and re-weld.
Similar to using a notcher and bender to make angle iron frames.:thumbsup:
/ Bush hog crazy wheel.... #23
I sure miss Visio since I am no longer in the corporate world. Microsoft has made it too expensive for my occasional/hobby use.
/ Bush hog crazy wheel.... #24
I was thinking the same thing.
2012 DRAGON 165BBL ALUMINU VAC TRAILER (A67714)
2012 DRAGON 165BBL...
2007 Ari-Hetra HDML-8 60,000lb Four Post Auto Lift (A66736)
2007 Ari-Hetra...
2016 Freightliner M2 106 Brush Hawg Grapple Truck (A66736)
2016 Freightliner...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
2011 CARGO CRAFT ENCLOSED GOOSENECK (A67714)
2011 CARGO CRAFT...
2009 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2009 INTERNATIONAL...
