Rotary Cutter Bush hog crazy wheel....
/ Bush hog crazy wheel.... #21
No problem, I just put the diagrams vertical to make the cut angle more clear.
Aaron Z
/ Bush hog crazy wheel.... #22
The problem is he is trying to mow vertical 90 degrees uphill.
But you guys hit the nail on the head. Need that caster.
If it were mine though, as opposed to cutting it off and rewelding, I'd burn a 30 degree triangle out of each side strap leaving about 1/4" of strap left. Bend til triangle closes up and re-weld.
Similar to using a notcher and bender to make angle iron frames.:thumbsup:
/ Bush hog crazy wheel.... #23
I sure miss Visio since I am no longer in the corporate world. Microsoft has made it too expensive for my occasional/hobby use.
/ Bush hog crazy wheel.... #24
I was thinking the same thing.
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
John Deere 630 (A64119)
John Deere 630...
