Rotary Cutter Bush hog crazy wheel....
/ Bush hog crazy wheel.... #21
No problem, I just put the diagrams vertical to make the cut angle more clear.
Aaron Z
/ Bush hog crazy wheel.... #22
The problem is he is trying to mow vertical 90 degrees uphill.
But you guys hit the nail on the head. Need that caster.
If it were mine though, as opposed to cutting it off and rewelding, I'd burn a 30 degree triangle out of each side strap leaving about 1/4" of strap left. Bend til triangle closes up and re-weld.
Similar to using a notcher and bender to make angle iron frames.:thumbsup:
/ Bush hog crazy wheel.... #23
I sure miss Visio since I am no longer in the corporate world. Microsoft has made it too expensive for my occasional/hobby use.
/ Bush hog crazy wheel.... #24
I was thinking the same thing.
2013 FORD F-150 PICKUP TRUCK (A66091)
2013 FORD F-150...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
Pallet of Golf Cart Tires (A64912)
Pallet of Golf...
PALLET OF TRASH PUMPS (A67714)
PALLET OF TRASH...
YALE FORKLIFT (A63291)
2012 Mitsubishi Fuso FEC72S Box Truck (A66736)
2012 Mitsubishi...
