Building my first Pole Barn with Concrete Slab - Help on first steps
   / Building my first Pole Barn with Concrete Slab - Help on first steps #21
I'd love to use the stuff you call "zip strip", but cannot figure out how to get it in place in the slab. Would anyone with hands on experience please explain how and when to use the strip stuff for crack control on a slab? Thanks!
Check it out here. Superior Profiles
MarkV
   / Building my first Pole Barn with Concrete Slab - Help on first steps #22
It is placed on the top of the wet concrete and then troweled flush into the concrete. It is made of plastic and sticks down aways into the concrete. Once the concrete has hardened, the top portion of the strip is pulled off (zip!) and a seam in the concrete is revealed. It is difficult to get the strips straight and requires a worker to walk across the concrete, set the strip in, and then trowel his tracks will coming back out. Sawing is easier and straighter in my opinion but the strips allow a weakened section immediately after placement.
   / Building my first Pole Barn with Concrete Slab - Help on first steps #23
So, timing-wise, its placed after screeding, or after floating, or after initial troweling? For least amount of destruction of finished work, I assume the sooner the better, so right after screeding maybe? If so, it seems that later operations like floating and such would depress the top of the "T" shape into the surface, only to have it removed later, leaving evidence. Sorry, I don't really get it.
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
LIGHT TOWER (A56857)
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A60432)
UNUSED AGT...
