Building A Bridge
/ Building A Bridge #61
3RRL said:
Plus, I don't think this statement is true.
.....and the liability is shifted from you to the engineering firm.
They may now share in the liability but you never get rid of it yourself. Heck, they may have a disclaimer in their report relieving them of all liability? IMHO, as long as it's yours, you will have liability for it.
IMAO - you have no idea what you're talking about. You're NEVER relieved of responsibility for engineering a structure (in this case the abutments). I could tell you long stories about engineering firms being sued for things that they only had a tangential part of. You're "IMHOs" are fine for you - but, I have the feeling you're neither a trial lawyer nor an engineer.
As far as the report goes, it would depend upon how it is worded - whether the firm certified the bridge to a certain load or only rendered an opinion. If it's only an opinion, the firm would not be held as liable - but, any hard engineering like the abutments - not a chance...you're totally liable for the design. Believe me - we have to take risk management courses yearly on just such differences...
That's the exact reason that the inspection engineers would give no more information than that in the report - and why they were "no help." They couldn't be. The report was not current and they can't professionally rely on information that is non-current on a structure that can change because of being exposed to environmental conditions.
/ Building A Bridge #62
Can't you just find out who built it from VDOT and get the ultimate load rating from the original plans. I bet CBI must have cranked out a million bridges that looked like that. All the girders are standard shapes.
Hey, Is that bridge in Madison county?
/ Building A Bridge #63
Geez swines, lol ... I must have pushed a button or something to get a response like that. If you reread my response, my IMHO refers to the owner of the bridge not getting away scott free of responsibility. I think in the event of an accident involving that bridge, regardless if God did the engineering report, any good attorney would file suit on everybody involved with it, including the owner.
So are you saying he (the owner) will not be held liable at all if the engineering company "certifies" the bridge then?
/ Building A Bridge #64
Toiyabe, your explanation is from a lawyers point of view:
the explanation from an engineers point of view is:
You can NEVER calculate for an exact maximum load that occurs during its life: the vibrations, jumps, load situation and distribution that occurs in practice over many years has too many variables to calculate it exact.
The safety margin is just to make up for all those variables that you cant measure or predict. No matter how advanced your analysis program is, you'll allways need to use a safety margin to stay ahead of the factors the calculation model misses.
If i'd calculate the bridge for him, i'd calculate the structure on the occurring tension. that's quite accurate.
To evaluate the outcome is another: where fine grain steel like Domex 700 laughs you in the face and will take a swell load for years without fatigue, standard St. 37.2 will snap instantly.
So any advice based on the outcome of the analysis will be based on standard St.37.2
The less accurate the calculation is, the higher the safety margin should be.
According to the engineering standards book, a jump and swell load needs a design safety factor of 1,5 and an alternating load needs a safety margin of 3.
If i give Koop an advice based on lowest grade standard steel 37.2 and a safety factor of 2, this safety factor covers the dynamic peak loads as well as a fatigue margin.
If you want to take it to the next level, you could FEM analyse it with the Von Mises stuff and see if you can lower the safety factor by analysing the dynamic loads etcetera, but thats a lot of work to rise the approved loads just by a few %... I dont think Koop is willing to pay an engineer with a FEM analysis program to get just those extra few % of permitted load... ;)
/ Building A Bridge #66
Good god.
DIN St. 37.2 is unheard of in the US. Nearest I can figure it is related to the ASTM 570 series, which is for sheet metal not thick structural steel sections. I presume you use the stuff to build trailers?
The rest of the stuff I guess you picked out of a mechanical engineering textbook. That's nice, but irrelevant to a bridge. I guess you should get a pass on jibberish like "jump and swell load" as english doesn't apper to be your native language.
Safety factors include more than just uncertainties about the future loads and load combinations. They also include uncertainties about material properties and section sizes. They also include acceptable risks, which vary according to application. There's a whole field devoted to the safe design of civil structures - it is called civil engineering. Don't re-invent the wheel.
Patrick_g, the stiffness of the bridge isn't the big issue. The strength is. You can't directly figure out the strength of a structure from its stiffness. For one thing, all common steels all have the just about the same elastic modulus, although strength varies widely. Fatigue damage is related to the ratio of cyclic strain to ultimate strain, not deflection. Bend thin sheet metal and a thick I beam through 90 degrees, the I beam will have much more strain at the extreme fiber.
/ Building A Bridge #67
I will not go into this in great detail as there is a zero WIFM index. If there is doubt about the strength and the bridge for some reason would flex too much for comfort at the intended weights then one simple cure is to put more supports under the bridge so spans are reduced.
The stiffness experiment was not intended to derive the strength of the bridge. It is a cheap, simple, and quick way to attempt to see if you can show the deflection to be so small as to not be an issue with the intended loads and strength of materials used. Who cares what the ACTUAL strength figure is so long as it can be shown to be sufficiently greater than needed?
Irrespective of bridge strength, the supports have to be good enough or the system fails. I hired a PE consulting engineer a few years ago. He brought out a sub contractor and helper with a drilling rig. We bored a 6 inch diameter hole and took samples every 6 inches till we hit solid rock. The PE analyzed the samples in his lab and issued a written report with his PE stamp. He made recommendations for my foundations and drain systems. This was a three story structure with massive amounts of concrete and steel so I wanted to build a foundation from a position of knowledge not good ole boy guess work.
The total cost of the engineer, report, subcontractor, the whole enchilada was less than $1000. This included designing various drain systems and the foundations. My liability DOES have access to his E&O insurance.
This was a bargain. The engineer was a professional in high demand. I got him through recommendations from the civil engineering firm I used. When I asked them to do the work they said it was out of their comfort zone (firm owner was PhD in civil engineering with several staff PE's) and they gave me the contact info for the consulting engineer they used. The point of this is that you can hire good help at reasonable prices. Your insurance company will be pleased if you get a PE to design the bridge supports and test the sub soil so the supports can be tailored to reality and not a one size fits all good ole boy estimate approach.
Everything should be made as simple as possible, but no simpler. -- Albert Einstein
The part that is often forgotten but is of paramount importance is the BUT NO SIMPLER part.
Pat
/ Building A Bridge #68
koop - You should be sued for starting this thread!!! Nice looking bridge , when it's installed give me a call . I'll drive up there and test it out , if it fails I won't sue you.....
/ Building A Bridge #69
Yes, in Europe we use DIN, NEN and ISO. Indeed i've used it to build trailers, hospitals, waste processing plants and more. Its the most widely type of steel used in Europe, also in civil engineering, in which i have worked before i got into trailers.
Right, my general engineering book says that the common rule for fatigue safety, is 1,5 for a load that amplitudes from 0 to +100% and a factor 3 for a load that amplitudes between a negative and a positive load. (anywhere from -1 to +100%)
Sure i didnt test it myself - these are empirically determined limits commonly accepted through engineering. Or to use your words:
I was reciting my dutch book, which i translated literally. Did i loose my credibility because my English isnt perfect ?? If you didnt notice that i'm a Dutchman untill this single sentence, i dont have to be embarrased of my English.
Very correct: the reasons i mentioned are only a few. You cannot rule out all factors just by safety margins, the chance of failure just has to be narrowed down to an acceptable level. For exapmple, in case of the dams, dunes and dikes around Holland: a chance of a flood every 10.000 years.
With safety margins to reduce the chance of failure to once in 10.000 years, you're no longer in the field of engineering, but in the field of lawyers.
The same as Koop's bridge with a safety margin of 2: if you want to determine if the risk of failure is acceptable, you'd need a lawyer and a risk analyzer, no longer an engineer.
/ Building A Bridge #70
Maybe for thin cold-rolled members, but not for thick hot-rolled members like those used in this bridge.
This may be usefull in mechanical engineering when the dead load is negligible compared to the live load. Not usefull for civil engineering where the dead load is always significant and often much greater than the live load.
You can't just pick numbers out of a book without knowing what they mean.
If you gave the dutch equivalent for "jump and swell load" then someone who really cared could figure out what it means. Your english translation of that term does not convey any information, however. If you were an english speaker, that term would peg my BS detector.
Which is why engineers use standard design practices, which specify how to design a structure with an appropriate margin of safety. There are many names for people who make things up as they go along, but engineer isn't one of them.
Anyway, the point is escaping me here. I wanted to explain to you why what you are proposing to do is dangerous. If I haven't convinced you by now, I don't think I ever will.
/ Building A Bridge #71
Hmm... are you trying to tell ME something about DIN standards ? :p
No, you didnt... And you dont accept my European engineering because it doesnt taste to your American mouth...... :) So i think its better to quit right here for both of us. ;)
/ Building A Bridge #72
What does a used bridge sell for anyway?
Have I stumbled onto Bridgebynet by accident?
/ Building A Bridge #73
I agree. The only help I would have asked for was the paint. Latex or enamel?
/ Building A Bridge #74
Woo-Hoo!!!
I can offer advice in this thread now too.
Never paint exposed steel with a latex paint. It won't last. Latex works best on a porous surface. Give it a good cleanup & paint with a rust-reducing primer, then a couple of coats of a quality alkyd enamel & it'll look good for a couple of years. (Unfortunately, no paint lasts forever outdoors...)
/ Building A Bridge #75
I am on year 4+ with steel columns (4x4x3/16) painted while lightly rusty. I used Rustoleum paint designed for painting rusty metal without a primer. The metal is out in the weather now for a bit over 4 years and looks like a new paint job. When/if it needs more painit I will most likely use the same product. It is a hammertone textured finish not regular gloss. It is glossy but not smooth and flat.
Pat
/ Building A Bridge #76
Now I know what kind of paint to use. If only somebody would give me a bridge, I would be in 7th heaven.
/ Building A Bridge #77
I have seen several old bridges obsoleted by new wider ones built parallel to the old. I have speculated as to the prospects for buying one and getting it trucked to my place. Most have been of steel (or iron for all I know, I did no testing) trestle type. Concern for moving expenses was an inhibiting factor but I didn't really get a quote so maybe it would not be prohibitive.
Not too far from me there is a fairly long old railroad bridge (trestle type) that was converted to automotive use after the railroad abandoned it. Someone set fire to the wood deck (after a spat with a lady friend who lived on the opposite side, ruining it for vehicular traffic when he burned his bridge behind him) but it was rebuilt with a concrete deck and remains in service across the South Canadian River connecting Wanette, Oklahoma with Byars, Oklahoma. Of course it is one lane and an interesting drive as it spans maybe 300 yards and is understandably narrow.
I expect since it was built for trains that it has some reserve strength when handling automotive traffic where there is seldom a car waiting while another crosses in the opposite direction.
It is a target for some in the pastime of geocaching.
Pat
/ Building A Bridge #78
Renze,
It is not the American part of his mouth that is speaking, nor the European part of your hand offering assistance. Thanks for offering to help the fella out.
I have met way more Europeans than Americans with the perspective of Toiyabe, and I live in the US(albeit in a University town).
Thanks again for offering to help the fella.
Chris
/ Building A Bridge #79
The Europeans you meet in a university town are mostly students, who usually just know their pre-chewed theoretical approach. As soon as they get into business and have to actually WORK for their money, they realise that only those who take risk and responsibility, are the ones that earn money in a business. The others get strangled by the competition in a healthy free market economy.
...i'm just a gearhead in a small invention driven company, hence my pragmatic approach. ;)
/ Building A Bridge
Shaley, Half the bridge will be in Madison county, the other half in Greene county. I contacted CBI who said their records on older structures are not very organized so it would be difficult to find the original plans. Basically they are not willing to do the leg work.
Patrick_g, you are the first person to address the fact that any engineer will just be making educated guesses about the bridge even if they are standing in front of it. A great point.
Dullpain, sorry I added to your pain. Get ready to pack your bags, the bridge will hopefully be set in about a month.
2manyrocks, The bridge cost just over $30,000 delivered from about 75 miles away. The other option we looked at was a 60' precast concrete superstructure which was about $50,000. The abutments would have been in the water which was undesirable.
Defective, since we are talking paint.... The current plan is to use an iron oxide primer for most areas and then an industrial grade enamel for a top coat. For the heavily rusted areas I am thinking I will try POR-15. Do you have any experience with the product?
Renze, Toyaibe, Kendall69, dynasim, Thanks for all the input. Remember, it does not hurt to speculate, guess and discuss, that is what this forum is about. It only hurts to act on pure conjecture.
The first footer has been poured, 17' x 8' x 4'. Two mats of rebar 12" on center. About 21 yards of VDOT A-3 mix. All work is being preformed by a licensed, pre-qualified VDOT contractor.
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
2009 Infiniti FX35 Multipurpose Vehicle (MPV), VIN # JNRAS18W09M158535 (A64557)
2009 Infiniti FX35...
New 10' Cattle Working Chute (A62679)
New 10' Cattle...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
New/Unused Landhonor No Till Seed Drill (A65583)
New/Unused...
