build a bridge, get over it
/ build a bridge, get over it #41
How do you allow for temperature expansion and contraction in the steel that will occur between winter temp and summer temp's? I'm not an engineer, so don't know what that steel expansion will be.
Also, will there not be any ground freezing and thus moving of the concrete abutements? Or will the stream keep the ground thawed under and behind the concrete?
If the concrete moves, will it shear the bolts off?
/ build a bridge, get over it #42
Anxious to hear how you will fasten the ties down to the I-beams. Also, what will you deck the bridge with, over the ties? Seems there is quite a bit more hard labor that you will be doing to finish this project, but looks like it will be a great bridge when you are done.
/ build a bridge, get over it #43
I think he will have to drill a hole through the tie, and through the beam and then bolt them down.
Here is a picture of a <A target="_blank" HREF=http://www.pbase.com/image/504780>bridge</A> my neighbor built. He used 8x8 ties, and put nothing on top of them. I guess he could have put some 2x8's where the tires would go -- that would reduce the wear on the ties, as well as quiet the ride.
/ build a bridge, get over it #44
You have the start of a very nice bridge. It appears that you have both sides of your beams bolted down. If so, I would highly recommend that you consider leaving the beams on one side of your bridge able to expand or contract in accordance with your local ambient temperatures. If you don't, its likely the bolts will shear off. It could also severely bend them and/or result in movement of the piers. I recommend you verify your design with the local highway department engineering group. They may suggest a different bolting method as well as placing a pad of some sort, teflon maybe, under the beams to insure reduced friction with they slide. I would hope they could suggest an easy fix as you don't have to comply with highway standards. Good luck!!
yes i thought about the expansion and contraction, there are some what of a slot cut for the bolts instead of just a hole.
in all the bridge failures i have seen in the past, none were bolt failures, most all were foundation failures.
/ build a bridge, get over it #46
<font color=blue>yes i thought about the expansion and contraction, there are some what of a slot cut for the bolts instead of just a hole.
in all the bridge failures i have seen in the past, none were bolt failures, most all were foundation failures</font color=blue>
How big are the slots? Did you leave the nuts a little loose, or torque them down tight.
The reason you see a lot of foundation failures is because the weakest link will break. Most bridges are built in the summer, When it gets cold the steel beams shrink and try to pull the concrete towards the stream. This loads the concrete in tension, and it breaks. Concrete is very weak in tension (compared to its compressive strength) that is why you put all that rebar & mesh in it.
Here are some calculations:
Coefficient of Thermal Expansion for A36 Structural steel 6.5e-6 in/(in-deg F)
Lets say your temp range is 100 degrees (you can probably find the actual at your local library or NOAA)
20Feet *12 inchs/foot *100 Degrees * 6.5e-6in/in-degree F = .156" (5/32")
So for 100 degrees you'll see the steel change 5/32", for 200 degrees it would change 5/16". If your slots are big enough, you'll have no problems/w3tcompact/icons/smile.gif. Just leave the nuts loose. They should be just touching the I Beam. You can spot weld them or use nylon lock nuts if you are worried about them vibrating loose. If you tighen the nuts they have a tremendous amount of clamping force, and corresponding friction & therefore won't let the bridge move.
Enjoy the bridge, it looks great/w3tcompact/icons/grin.gif
bridge with first real test
With all the snow and rain we have had my bridge got its first real test of high water, the water is about two feet deep here and moving very fast. bridge did very good, but this was not as high as flood of 85 would have to add about another foot of water to match that level.
/ build a bridge, get over it #49
Re: bridge with first real test
I love that bridge. It appeals to the puttering desire to build in me! /forums/images/graemlins/grin.gif Nice work!
Pete
/ build a bridge, get over it #50
Nice job, can't wait to see it finished. If you had not hit solid rock when digging for the foundation, how deep would you have had to go for proper support. I am considering a similar project in the future.
I guess a lot of how deep i would dig would depend on the soil. Not to many places up here in the mountains that you can't hit something solid after digging 3 or 4 ft. If i was building somewhere the soil was soft like sand or something, i guess i would make the footprint of the footer larger to spread out the weight to keep the bridge from sinking. Sinking would be my largest worry if i could not hit something solid. other than water getting under it from the soft soil being eroded away.
The picture i added is from the same day, it shows just how much water we had from a distance.
/ build a bridge, get over it #52
Just out of curiosity how difficult was it in Virginia to get approval for construction in a waterway? Here in Maryland I'm guessing it would be next to impossible to get a permit.
/ build a bridge, get over it #53
A job well done. That one should be around for years.
umm uhh umm yeah umm
/ build a bridge, get over it #55
What was that, MRHURT? I couldn't quite understand you. /forums/images/graemlins/wink.gif
update on the bridge project
the weather has finally gotten better so i got back on the bridge kick. here is a few pictures of what i did.
Re: update on the bridge project
here i'm getting the walkways out of the creek, used to keep mine and the wife's feet dry while bridge building
here is a shot of the boss hard at work
here is the view from the house side of the creek.
got just a little to build up to. /forums/images/graemlins/smile.gif
view from the other side
