Bucket Hook Project
/ Bucket Hook Project #22
My local JD dealer has them in parts bins on the parts room floor for customers to pick out what they need without assistance. They sell a lot of parts that way to people that come in for a specific part that is behind the counter. While you are waiting for your part, you just browse the isle of all sorts of goodies. My local Kubota dealer has a similar set up, but not nearly as extensive.
Dusty
Dougster,
I don't mind at all. I have an industrial supply store in the area and they just had them in a bucket. I think they were about $7.00 ea.
/ Bucket Hook Project #24
Sandlot said:
Dougster, I don't mind at all. I have an industrial supply store in the area and they just had them in a bucket. I think they were about $7.00 ea.
Thanks guys. I'll take a look around here, but I'll bet I'm going to have to send away for them. It's definitely worth it for the professional look and extra strength.
I just wish I could weld like that too! :)
Dougster
/ Bucket Hook Project #25
Sandlot said:
Thanks Guys,
Yep, those fuzzy people are spoiled rotten!
I welded the ¼” plate all the way across, just in case I wanted to add hooks facing the other direction. With the bucket tilted in the full up position and load close to the tractor, hooks facing opposite the norm maybe handy. I think I will add a bit more weld to the plate at each hook; the rest is just more or less a seal weld to keep water from getting under the plate. I bought the hooks like that from an industrial supply store in town. I have more plate leftover, for the hoe bucket. That will be another weekend. I had the Lasik surgery 6 months ago, but it was for distance, now I need reading glasses. It was a fair trade off. I needed glasses for everything but real close, now just for reading. I’m satisfied.
Sandlot, next time you go to that industrial supply store, ask them where they get those hooks. I sure like to get my hands on three of them. Can't seem to find any in my neck of the woods.
/ Bucket Hook Project #26
Have you tried you local steel supply? That's where I got mine.
/ Bucket Hook Project #27
Sandlot,
Excellent welds! They are just beautiful.
That is my slogan you quoted in your opening post and it's true, isn't it? Hahaha
Just another thought on hook placement and angled or straight. Mostly, it's a matter of preference and I chose to angle mine inwards a bit. I use 2 chains to lift and the object is generally closer to the center of the bucket. So I angled mine in. I try not to lift with just one hook, especially if it places a lot of force on the one fel arm. I also welded my hooks on the back of the bucket (on a support plate) not on top of it.
PS,
My welds are not as nice as yours, but they used to be.:)
/ Bucket Hook Project #28
3RRL said:
Sandlot,
I am getting ready to weld hooks onto my bucket and also plan to reinforce it under where the hook will be welded. I am curious why you chose to weld your hooks to the back of the bucket rather than the top? What advantage to you see being gained by doing that? Not being critical of your decision, I just want to do the job the best possible way and to gain the maximum advantage.
/ Bucket Hook Project #29
Thanks for asking.
One advantage of the grab hook style is you need constant pressure to keep the chain in. In my use, by mounting on the back, the chain drapes over the top adding that tiny little bit of added resistance to it falling out of the hook.
I also imagined hooking the chain with the bucket dumped to some degree so I would have more lift using the curl and also to set the chain tautness without lifting the bucket up.
In the dumped position, which now exposes them upwards, they are not between what you are lifting up (if it's close to the bucket) so they're easier to get to in that case. Plus personally, I think it looks better to have them sort of out of the way....maybe a safety factor there too?
These are of course my personal opinions for the manner in which I use my hooks, so others have their opinions about the top of the bucket placement which works out better for them. I don't know how much difference it REALLY makes though, so it boils down to personal preference. Both positions will certainly work.
Another reason is that I was planning on adding a bucket grapple and did not know (at the time) how and where it would go. So I left the top lip open for that project.
Weldable Grab Hooks
I found this link for the hooks. I haven't been back to the big city for awhile to ask the industrial supply store where they get theirs. Hope this helps.
Morgan 26ft Box Truck Body (A59230)
Morgan 26ft Box...
yellow ball Trailer (A56859)
yellow ball...
2014 FORD F-550 XL SUPER DUTY UTILTY/SERVICE TRK (A59823)
2014 FORD F-550 XL...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2007 Jeep Liberty 4x4 SUV (A59231)
2007 Jeep Liberty...
