Broken 1230 issue
/ Broken 1230 issue #1
De La Farmer
Missouri
Massey Ferguson 1230 4x4 Hydro
Hey everyone,
I posted a question about this issue about a month ago and never got any pictures to go with it. Now I've got them and hoping some of you can weigh in on what might be causing the gap. Note: the rattling sound in the video is my FEL not my tractor.
Another thing I noticed is how the steering seems to be very stiff when the bucket is up. I haven't used the bucket aside from just lifting it up to operate the tractor since this problem started.
Use this link to view my video: http://www.youtube.com/watch?v=iMJbgEWKHkI
Thanks again,
/ Broken 1230 issue #2
Thats odd! do you have pictures of the frame below ?
/ Broken 1230 issue
No, but the frame is intact and there aren't any cracks. My neighbor and I had it on a lift and went over the frame and came up with nothing. :(
/ Broken 1230 issue #4
Wow! Is the tractor as new as it looks? Talked to the dealer yet? If mine did that, I'd be real concerned!
/ Broken 1230 issue #5
Does the loader hook to the front of the tractor frame also? I can't imagine that sheetmetal moving like that without the frame being broken.
/ Broken 1230 issue
I haven't contacted the dealer yet, and after looking at the frame from under the tractor is looks to be in good shape. Nothing is separating from itself, and the only thing that looks to be showing any sign of stress are the motor mounts. I didn't think that would be it though.
It's a 1997 with 926 hours. My bucket is a Westendorf TA-111. Personally, I think it's too much bucket for my size of tractor.
/ Broken 1230 issue
The loader hooks to the front of the tractor frame and then also slides into brackets at the midsection. Here are a couple pictures of my loader.
/ Broken 1230 issue #8
thats exatly what my 1250 was doing ,,it had to get really bad before i found the trouble....i couldnt see anything wrong until it really got so bad it was really broke..that may not be the case with yours but it sure looks the same,,when mine broke i didnt even take it apart ..a welder buddy was able to repair it on the tractor.... hope you find your trouble bruce
/ Broken 1230 issue
So what was the problem with yours? Did your frame actually crack? When your welder buddy fixed it, has it been ok since?
Thanks for your input.
Steve
/ Broken 1230 issue #10
yes it actually broke ..after he welded it i kept the tractor 2 more yrs with no more trouble at all ...the only reason i got rid of it was i went to a little bigger tractor ...my 1250 was a tough tractor ... bruce
/ Broken 1230 issue #11
i found a post about a 1140 mf that did the same as mine..it may help you..not sure how to put a link to it ..it was posted by nick79 mf 1140 broken frame. it has pictures that look the same as mine...... i hope this helps ,,,,, bruce
/ Broken 1230 issue #13
I was talking with a friend the other night on the phone. His dad has a Massey in the 40-50 hp size, dont know the model. However, he said that his dad just broke the frame on his tractor! I thought I had heard of a Massey story like that before. I know them both very well, but they live about two hours away. Hopefully I'll be able to get some more information or some photos to share with you guys. This tractor is well out of warranty as is yours. I wonder if the dealers hear about all these instances when it happens out of warranty. Seems to be happening enough that there is a design defect that massey may aknowledge and help out with. Worth a conversation with your dealer in my opinion.
/ Broken 1230 issue
Looks like I need to recheck my frame and see if there are any cracks around the bolt holes. That other post gave me a couple of ideas on where I should look. I was using it today without the bucket and just the weight of the loader mount was enough to cause the gap. The tractor still runs great. I regraded my drive way with my blade and then I sprayed about 8 acres with some weed killer and it ran fine the whole time.
One thing to note is when I use my bucket it seems like my power steering is spotty. It feels like there's points when I'm turning the wheels where it sticks. I can still turn the wheels and it works ok, but I can tell something isn't right.
Thanks again for everyone's input.
Steve
/ Broken 1230 issue #15
just wondering how you came out with your tractor ?? hope it turned out well ...bruce
2012 PROCO 130BBL (A65643)
2012 PROCO 130BBL...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
Club Car Emergency Cart (A64557)
Club Car Emergency...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
