Bridging a Creek
/ Bridging a Creek #21
The method of positioning a telephone pole was addressed locally last year by a fellow here in Vermont facing the same problem. He solved it by buying a couple of VW hoods from a local junkyard, lashing one end of the pole to it, and pushing the other end. The hood acted like a sled keeping the end of the pole from digging in. Seems like desperation is the mother of invention, huh?
Pete
www.GatewayToVermont.com
/ Bridging a Creek #22
<font color=blue>Can't be sure if your tongue is planted firmly in your cheek</font color=blue>
Not at all. I've seen a bunch of bridges built on logs and poles; especially for short spans. They work great until the wood rots, and the result is not pretty. If I was to build a bridge on poles or logs (any wood), I would think long and hard about how I would protect them from rotting. Supporting them on a concrete abuttment migt be a start...
As for stressing the rebar, tensile strength of high-grade steel is about 125K PSI, and rebar is not "high grade". I would back off from that number considerably; maybe 25K PSI. Although for the short span we are talking about here, I don't know that you'd have to worry about it too much.
The GlueGuy
/ Bridging a Creek #23
Glenn,
I built two bridges. One with an old truck bed because a guy down the road had it and wanted to get rid of it. The other one with telephone poles. I get gulley washers and both are still standing. When the rain is really bad my creek turns into a river. On the truck bed one I used rough oak and treated it and screwed it into the bed.
For the telephone poles I would use three. I saw a guy one time only use two and it broke on him. The one I did I cut away the bank and layed the poles flat. Then I again used rough cut oak and layed across for planks. I've taken everything across it and no problems.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Sakai SW354 (A60462)
Patterson water pump (A59230)
Patterson water...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Kubota L4701 (A53317)
(10) Rolls of Galvanized Wire (A60463)
(10) Rolls of...
