DIY Bridge
/ DIY Bridge #101
I agree with one thing, you need to do something. A bridge or culverts with a concrete top that allows water over the top during high flows would both be good solutions.
/ DIY Bridge #102
If you are going to dig the creek bed for a bridge that's probably fine but for culverts, I would advise against it will only fill back up with sediments and your culvert will end up half full of dirt within a few years...
We built a low water bridge at the local non-profit camp and the leader decided (against a lot of advice, but he knew better) to put in ten 12" diameter X 8' long concrete pipes to save money. Creak is ~18' wide with very little to no slope, and dry most of the year. 5 years later its a low water dam.
You need the right amount of slope and big enough diameter so that the flow can/will flush the sticks and debris out.
/ DIY Bridge #103
My point is if you excavate the creek bed downstream and/or upstream it will simply get filled back up especially in a sandy shallow waterways ... you can't make a creek steeper by simply dig it in, well you can but it won't stay like that... lets say the creek flow at 1% slope, you dig in a slope at 3% for 50 feet. You will have a foot tall ledge at the end (excavated creek bed to original creek bed elevation differences) that ledge will trap sediments and gets filled back up until the creek bed is back at its original grade and you dig that for no reason.
/ DIY Bridge #104
Man vs. Nature 😟
/ DIY Bridge #105
In a 50-yr career building stream crossings for 100K lb log trucks I learned that bridges are always better than culverts. They take more careful planning and are more expensive to build initially, but they will always pass more water--and with less impact--than culverts. If the terrain in your case will allow it, build relief dips on both sides of the bridge. When the flood waters get high enough to lap at the bottom of the bridge you want them to continue downstream by going around the bridge, not over it. When the water subsides it will be much easier and cheaper to repair the eroded roadway on both sides of the bridge than repairing the bridge itself.
/ DIY Bridge #106
I find the situation pretty challenging, the problem I see here for a bridge, or a culvert for that matter is the creek has no banks, so lots of material is going to be required to raise the road, in order to create the bridge abutments to create enough elevation to allow room for the water to go under at high water level...even for a culvert lots of material is going to be needed... I hope he can get his hand on some cheap material.
/ DIY Bridge #107
Now that we're finally getting too much rain here in California all at once I'm glad I have a bridge with lots of clearance (8' high and 48'wide). My creek went from being ankle deep and 8' wide to up 5' deep and 35' wide on several occasions in the last month. As far as the idea of letting water over flow a hard surface or coming out of a culvert, I've seen what I call the "waterfall effect" where the running water scours out the downstream side of the discharge point eroding the creek bed when experiencing high flows. Often it may fill back up with silt when the fast flowing water subsides but often leaves of hole, or a pool, check out county culverts in your area. Also I've seen where the displaced material can create a sandbar barrier that further down that also alters the flow to one side or the other downstream. Whatever you decide, I like that quote from a movie of Morgan Freeman, " Go big or go home"!
/ DIY Bridge #108
Dittos in Sierra foothills and all up and down the San Joaquin Valley ....
/ DIY Bridge
“If the terrain allows it, build relief dips on both sides of the bridge.” This sounds like a good idea. Certainly something to look into. Thanks.
/ DIY Bridge
So, I talked with a guy today, who does excavation, and he’s been building bridges (over creeks) with ‘retired’ flatbed trailers. The flatbeds are usually 48’ to 53’ long. In many cases he welds two trailer abreast so the crossing is 16’ wide. They also install buttress blocks, rip rap rock & gravel. He’s supposed to call me tonight to let me know when he can come & look at my situation. (Hasn’t called yet)
We’ll see what he has to say soon I hope.
2014 KEYSTONE COUGAR CAMPER (A60736)
2014 KEYSTONE...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2020 SAVANA 3500 4X2 S/A 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
JOHN DEERE 4450 TRACTOR (A59823)
JOHN DEERE 4450...
