Bridge repair
/ Bridge repair #41
Thanks for the update!!!
You really started out with a diamond in the rough with an amazing transformation!!!! The riprap and rock on the road make a huge difference, almost as impressive as what you accomplished by taking out those logs from your pond.
It's just beautiful.
Eddie
/ Bridge repair
Thank you for the kind words Eddie! You are right in that my wife and I put a lot of physical and mental labor into this project and it seems it takes manual labor rather than machinery to do things right. Not that machinery doesn't have its purpose because it very much does.Now I have the issue of every time the water runs off under the bridge it washes with it from the pond the limbs and tree trunks what we cut so the clean-up continues but it's bound to end soon wouldn't you say? It a labor of love and we are laboring :rolleyes:
Need to crank my Yanmar today haven't started it in a month or so...Hope she cranks right up, as she always does and I'll put her to work removing tree trunks for more pond clean up.
Take good care Eddie!!
/ Bridge repair #43
Looks great. A bridge is the one project left on my list of things, I would like to design an build.
/ Bridge repair
She cranked right up....absolutely love my Yanmar!!!
ray66v, if you need pragmatic hints feel free to drop me a line. I'd be glad to land a hand.....
/ Bridge repair #45
Thanks, I haven't built one because I don't have a need, and have not yet had someone to hire me to build one.
/ Bridge repair #46
Has the county OK'd the new bridge?
Up here we would have gone to a small local mill (dozens to choose from) and had some 3X10 hemlock timbers cut for cross pieces, then a second layer of 2X10s run lengthwise accross the bridge for the tires to ride on.This spreads the loading out between more of the cross pieces. Locally we figure 3" pine won't last more than a few years as it stays wet all winter and PT wood is over twice the price of rough cut hemlock which should last 20yrs with NO treatment.
/ Bridge repair
pat32rf, there was no need for the county to ok the bridge, it's solid as it can be!
I also went to the local mil for the timber I used, yes it is pine, hemlock's hard to come by here, but I've been treating the pine with my home brew of 1 gall of used motor oil added to 5 galls of diesel (mix was recommended to me by the mil owner).
Here's a pic of the wild life I get to enjoy around here
/ Bridge repair
Yesterday was a wonderful day in North Alabama. We had a snow fall and this was the first time I've seen snow on my property (have owned it for close to 4 years). Below is a pic of the snow covered bridge. I know this is nothing to those of you that live up north but to us it was a very refreshing change, wish it had lasted a bit longer.
This pic is at my falls which is the spring that feeds my pond
This pic is of the stream which leads to the pond
/ Bridge repair #49
Absolutely beatiful pictures!!!!
Thanks,
Eddie
/ Bridge repair #51
Just an idea but, a friend of mine had the same issue in Washington. His solution was buying a flat railroad car and I guess they can be picked up for cheap. From my understanding this is common practice in WA and OR.
/ Bridge repair
Airic, I am not sure I understand you point. Do you mean buy a flat railroad car to replace the bridge?
2011 International DuraStar 4300 Altec AT40C 34ft. Bucket Truck (A64194)
2011 International...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
1997 Jeep Wrangler 4x4 Off-Road SUV (A64194)
1997 Jeep Wrangler...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
