Better Brush Forks?
   / Better Brush Forks? #11
If your tractor will handel it, start with their wide frame: Construction Attachments, CAL, X-Treme Duty Skid Steer, Skidsteer, Wide Frame Brick Fork 1PFWFBF, Universal Skid Steer Quick Attach
   / Better Brush Forks? #12
Yep, and if they are the type that uses a ground rod to attach the pork to the carrier, you can put two on the rod and have 4 forks that way.
Aaron Z
Yep, I have Pin Top Forks that go on a round rod:
And the 2" square Block Forks:
I could combine them on one carrier, but I have a grapple, so have never needed them for brush.
   / Better Brush Forks? #14
It has been a while, but I'll bet I didn't. I'll go back and check. I would feel pretty stupid if that worked, but it wouldn't be the first time.
I would still love to have something that replaces the whole bucket, but since no one has suggested such a product, my guess is that it doesn't exist.
Might be cheaper just to keep it as you have it and buy another bucket.
   / Better Brush Forks? #15
I bought a cheap set of Titan forks ($251 at the time), and then fabbed up some other tines with some junk angle iron I had laying around. They work great! You could bolt your forks onto this platform.
How hard is it to remove a bucket? Is it an unholy torment like trying to remove things from a three-point hitch?
   / Better Brush Forks? #17
Assuming you have a pin on bucket it’s worse than a 3 point implement. The bucket is a pretty sucky mount for forks. I’d weld 2 pieces of channel iron or tubing across the back and put the pin mounts on that.
   / Better Brush Forks? #18
Easy - SSQA (Skid Steer Quick Attach). Lift 2 levers and it's off.
   / Better Brush Forks? #19
Here are Titan clamp-on debris forks.
I better see if I can work those turnbuckles before I go any further. I really think I failed to loosen the nuts. It was last year, so I can't say for sure.
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
(10) 20'...
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
2025 GIYI GY-X380 Trencher Mini Skid Steer Attachment (A50322)
2025 GIYI GY-X380...
7021 (A50322)
7021 (A50322)
