Best way to cut large tire in half?
   / Best way to cut large tire in half? #22
Thrrow it in the log splitter with a block of wood behind it so it will cut all the way through . Vertical tilt splitter ...
Great suggestion...!
I have grinder, sawzall and oscillating tool, so hopefully one of those works.
   / Best way to cut large tire in half? #24
I've cut several tires using a 7 1/4" circular saw with a fine tooth carbide tipped blade. It does smoke so you have to go slowly. The carbide blade will cut the wire bead but I usually snip them first with a bolt cutter.
   / Best way to cut large tire in half? #25
I agree with burrying half the tire.
What keeps cut tire from just falling over?
   / Best way to cut large tire in half? #26
Yeah, I'd just bury it.
My plan was to cut a 6 foot tire in half, then bury each half 1 foot deep. Lot less digging and easier to move, and my goats are small so 2 feet tall is plenty.
   / Best way to cut large tire in half? #29
How big are those tires? Maybe I’ll get smaller ones and not cut them.
I have no idea, really. I lifted the pics off the 'net. The second one looks like 14.9 - 24. ??
   / Best way to cut large tire in half? #30
Tire shop might do it for cheap ($50), but given tire season ... you might need to wait a bit before they get to it. i think OP wants two large halves, so perhaps only ends buried ???
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
White Metal Roof Panels (A55758)
White Metal Roof...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
SKID STEER SCARIFIER ATTACHMENT (A55745)
SKID STEER...
2006 INTERNATIONAL 9900I DAYCAB (A55745)
2006 INTERNATIONAL...
