Best way to cut large tire in half?
   / Best way to cut large tire in half? #31
IMPO, just about any alternative has to be better than the pain of cutting a tire in half not to mention the possibility of exposing wires that someone or some animal could get cut on.
   / Best way to cut large tire in half? #32
You could put a couple bolts near the edges of the halves and sink them into some concrete but you probably don't want concrete there either... use anchors (maybe bend rebar into long "U" shape and hold them down via the bolts, driven into hard ground, but at some point it's going to get tipped over and then I agree with 2manyrocks above, don't want that exposed metal out where jumping goats are goofing off.
   / Best way to cut large tire in half? #33
Backwards blade on the skill saw didn't have much too trouble cutting a car tire all the way around through the steel belts. Just hold onto it tight with two hands. Having some wooden wedges handy would help keep the cut open.
   / Best way to cut large tire in half? #34
Was getting my tractor tire repaired recently. Saw a guy cutting up old tractor tires with sawsall. They have to cut them to throw them away.
   / Best way to cut large tire in half? #35
Cut the steel cable in the bead with an angle grinder. After that a sharp knife will cut across the tread. Or continue with the angle grinder, just wear a mask to protect from the rubber dust. If you must use multiple tools then any wood cutting blade will do the tread and sidewalls.
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2002 FREIGHTLINER FL80 (A58214)
2002 FREIGHTLINER...
2017 Jacobsen Greens King IV Plus 62in Reel Commercial Mower (A56857)
2017 Jacobsen...
