Best way to cut large tire in half?
   / Best way to cut large tire in half? #12
Wedge a block of wood where you will be cutting, or the rubber will just spring back and forth with the sawzall blade.
Thanks, it will be enough cutting I’ll try both options.
   / Best way to cut large tire in half? #14
If you can put a band of sheet metal or tin foil around it you can cut it with a plasma cutter.
It'll be messy and stinky, but no worse than a skinny wheel and probably a lot quicker.
   / Best way to cut large tire in half? #15
FWIW...If the hot rubber gums up the blade WD40 or something similar will keep it sawing etc...
   / Best way to cut large tire in half? #16
I once had to cut stall matts,
Discovered liquid soap to be a good lubricant.
Folding over a 2 x 4 was a good help.
On a tire ,soap might be your best bet.
   / Best way to cut large tire in half? #17
I cut pickup tires off a rim with a Sawzall, but that's a lot smaller than a tractor tire. Once the bead is cut I would be tempted to try a chainsaw. Use caution if you try that though, the chain tends to bounce off more than when you are cutting a tree down.
And don't ask me how I know that... ;)
Once you get a hole started, they cut just fine... until you hit steel.
   / Best way to cut large tire in half? #18
   / Best way to cut large tire in half? #19
Whichever method you use, the end of the bead wires will still stick out and the critters will maybe hurt themselves...
   / Best way to cut large tire in half? #20
CAT 289D3 (A58214)
CAT 289D3 (A58214)
2014 Volvo L60G Articulated Wheel Loader (A56857)
2014 Volvo L60G...
1995 Kenworth (A57148)
2009 Arco Trailer T/A 6,000 Gallon Tank Trailer (A56858)
2009 Arco Trailer...
2013 TYTAL CRUDE TRAILER (A58214)
2013 TYTAL CRUDE...
LOT: (2) Truck Brake Part #'s 66864B, (2) Truck Brake Part #'s RK8354709E2 (A59076)
LOT: (2) Truck...
