Best way to cut large tire in half?
   / Best way to cut large tire in half? #22
Thrrow it in the log splitter with a block of wood behind it so it will cut all the way through . Vertical tilt splitter ...
Great suggestion...!
I have grinder, sawzall and oscillating tool, so hopefully one of those works.
   / Best way to cut large tire in half? #24
I've cut several tires using a 7 1/4" circular saw with a fine tooth carbide tipped blade. It does smoke so you have to go slowly. The carbide blade will cut the wire bead but I usually snip them first with a bolt cutter.
   / Best way to cut large tire in half? #25
I agree with burrying half the tire.
What keeps cut tire from just falling over?
   / Best way to cut large tire in half? #26
Yeah, I'd just bury it.
My plan was to cut a 6 foot tire in half, then bury each half 1 foot deep. Lot less digging and easier to move, and my goats are small so 2 feet tall is plenty.
   / Best way to cut large tire in half? #29
How big are those tires? Maybe I’ll get smaller ones and not cut them.
I have no idea, really. I lifted the pics off the 'net. The second one looks like 14.9 - 24. ??
   / Best way to cut large tire in half? #30
Tire shop might do it for cheap ($50), but given tire season ... you might need to wait a bit before they get to it. i think OP wants two large halves, so perhaps only ends buried ???
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
2016 Ford Explorer AWD Sedan (A55853)
2016 Ford Explorer...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2015 Ford F550 Bucket Truck - Versalift VST47 Boom - Powerstroke Diesel - Automatic - 4X4 (A55302)
2015 Ford F550...
GROUND PROTECTION PAD 8X4 15 COUNT (A55745)
GROUND PROTECTION...
48" WIDE WOODEN W/ METAL RAILING (A54757)
48" WIDE WOODEN W/...
