Best offset wheel disc?
/ Best offset wheel disc? #1
Blue Planet
Without breaking the bank, need a heavy, max 8' wide wheeled disc for my Kubota 7040SUHD. What have you guys found to be the most reliable and effective brands/models? We have Domries out here--good reputation, very few on the used market and very expensive new.
/ Best offset wheel disc? #2
Generally, anything and any brand over about 30 years old is a good buy. They are heavy, low-priced, "easy" to repair, and parts are usually available. You may need to replace some disc blades and a bearing or two but the repairs will never approach what a new disc would cost.
Unless you are in a hurry I'd check Craigslist in a reasonable radius to see what you can run across. Wait for a good buy.
The photo below is not a wheeled disc but the price was right - free. A friend wanted it off of his property when he bought his place.
/ Best offset wheel disc? #3
I don't know about the "not breaking the bank" part but Athens Plow Co. makes a good disk. One of the members here just restored one:
http://www.tractorbynet.com/forums/attachments/227696-restoration-old-athens-offset-harrrow.html
I am sure the price of a new one would scare you to death:
If you can find a used one you can most likely get any part for it from Athens. I bought an old Athens 7 shank chisel and needed parts. They had all that I needed.
/ Best offset wheel disc? #4
Most of the really old ones I see are pasture ornaments (worn out) but will still do a bit of work. When the disc blades are about 4-6 inches smaller than original, they need some $$$ thrown at them.
Be sure to price all the bearings and seals before you buy a clunker, it really adds up fast.
Wow--what an awesome restoration job!
And yes, the sticker shock of a new one is breathtaking. I've also noticed that used wheel discs are significantly cheaper in the Midwest than on the west coast.
/ Best offset wheel disc? #6
Don't know what your budget is, but check with dealers. Sometimes they take wheel discs and other implements as part down payment on a new tractor. My dealer sold me a 13-ft Minneapolis Moline KS1300 tandem wheel disc (not an offset) he took in from a customer for $600 and delivered it to my place. I cut it down to about 8 ft so I can pull it with my Mahindra 5525.
Good luck.
/ Best offset wheel disc? #7
I couldnt imagine pulling that disc with my 70hp kubota,did you ever hear if it did okay. Was very nice when he got done.
/ Best offset wheel disc? #8
This is a 9' JD that dad bought around 1970, was our main tillage unit. JD made a smaller model, if you can find one. We pulled it with a 58 HP 720D. ~~ grnspot
/ Best offset wheel disc? #9
Apparently I need to preview my posts better. I intended for the second link that I posted to be this one: Athens Plow - Model 127/167 Pull-Type Offset Disc Harrow
As to the link to the project disk, he has not posted anything about using the disk. I think his tractor will pull it depending on the soil but it won't want anything else.
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
iDrive TDS-2010H...
2362 (A64281)
2362 (A64281)
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2017 Hino 155 16ft. Box Truck (A61573)
2017 Hino 155...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
