Best offset wheel disc?
/ Best offset wheel disc? #1
Blue Planet
Without breaking the bank, need a heavy, max 8' wide wheeled disc for my Kubota 7040SUHD. What have you guys found to be the most reliable and effective brands/models? We have Domries out here--good reputation, very few on the used market and very expensive new.
/ Best offset wheel disc? #2
Generally, anything and any brand over about 30 years old is a good buy. They are heavy, low-priced, "easy" to repair, and parts are usually available. You may need to replace some disc blades and a bearing or two but the repairs will never approach what a new disc would cost.
Unless you are in a hurry I'd check Craigslist in a reasonable radius to see what you can run across. Wait for a good buy.
The photo below is not a wheeled disc but the price was right - free. A friend wanted it off of his property when he bought his place.
/ Best offset wheel disc? #3
I don't know about the "not breaking the bank" part but Athens Plow Co. makes a good disk. One of the members here just restored one:
http://www.tractorbynet.com/forums/attachments/227696-restoration-old-athens-offset-harrrow.html
I am sure the price of a new one would scare you to death:
If you can find a used one you can most likely get any part for it from Athens. I bought an old Athens 7 shank chisel and needed parts. They had all that I needed.
/ Best offset wheel disc? #4
Most of the really old ones I see are pasture ornaments (worn out) but will still do a bit of work. When the disc blades are about 4-6 inches smaller than original, they need some $$$ thrown at them.
Be sure to price all the bearings and seals before you buy a clunker, it really adds up fast.
Wow--what an awesome restoration job!
And yes, the sticker shock of a new one is breathtaking. I've also noticed that used wheel discs are significantly cheaper in the Midwest than on the west coast.
/ Best offset wheel disc? #6
Don't know what your budget is, but check with dealers. Sometimes they take wheel discs and other implements as part down payment on a new tractor. My dealer sold me a 13-ft Minneapolis Moline KS1300 tandem wheel disc (not an offset) he took in from a customer for $600 and delivered it to my place. I cut it down to about 8 ft so I can pull it with my Mahindra 5525.
Good luck.
/ Best offset wheel disc? #7
I couldnt imagine pulling that disc with my 70hp kubota,did you ever hear if it did okay. Was very nice when he got done.
/ Best offset wheel disc? #8
This is a 9' JD that dad bought around 1970, was our main tillage unit. JD made a smaller model, if you can find one. We pulled it with a 58 HP 720D. ~~ grnspot
/ Best offset wheel disc? #9
Apparently I need to preview my posts better. I intended for the second link that I posted to be this one: Athens Plow - Model 127/167 Pull-Type Offset Disc Harrow
As to the link to the project disk, he has not posted anything about using the disk. I think his tractor will pull it depending on the soil but it won't want anything else.
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61572)
1984 Charles...
72" JCT TILLER (A62613)
72" JCT TILLER...
Alliance Rear 16.9/14-38 Clamp On Rims (A64119)
Alliance Rear...
2015 Freightliner (A64119)
2015 Freightliner...
John Deere 1025R (A62177)
John Deere 1025R...
Caterpillar D5H Series 1 and 2 Dozer Service and Parts Manuals (A63117)
Caterpillar D5H...
