Bench Grinder - Flexible Shaft
/ Bench Grinder - Flexible Shaft #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Want to put a flexible shaft on my bench grinder for the purpose of attaching 4 inch to 8 inch cotton,sisal,muslin polishing pads. Having no luck in finding. Can anybody here help - please!
Don't suggest Foredom or Dremel, they are all too small. Particulars are below
Bench Grinder with a threaded arbor, 1/2 inch x 20 threads per inch, Right Hand threads, 1/2 H.P. , 3580 RPM.
I would like a 48" to 52" flex shaft to attach to this grinder. I need to attach 4" - 8" cotton , sisal, buffing wheels to output end. Buffing wheels will have 1/2 inch hole for attaching to flex shaft. Also would like to have a chuck or collett for using smaller mandrel buffs with a 1/4 inch mandrel.
Any help appreciated
/ Bench Grinder - Flexible Shaft #2
Grainger or McMaster Carr both have them online. /forums/images/graemlins/smile.gif
/ Bench Grinder - Flexible Shaft #3
This is what I use for buffing.Maybe you can do the same. I removed the 1/2" nut and replaced it with a chuck. Works great.All I did was to cut a hole in the out board guard.
good Luck
gugy
/ Bench Grinder - Flexible Shaft #4
Geeze, you should have posted earlier. A month ago, I tossed a 6' flex shaft that my dad used (very little). I've kept it hanging in the garage for 10 years--and finally decided it wasn't worth keeping...............
UGH.
Ron
/ Bench Grinder - Flexible Shaft #5
</font><font color="blue" class="small">( Geeze, you should have posted earlier. A month ago, I tossed a 6' flex shaft that my dad used (very little). I've kept it hanging in the garage for 10 years--and finally decided it wasn't worth keeping...............
UGH.
Ron )</font>
Isn't that the way it always goes /forums/images/graemlins/confused.gif. Wife tells me that I'm a pack rat. But every time I get rid of something, the above statement holds true. Gerard
/ Bench Grinder - Flexible Shaft #6
The next time the wife calls you a pack rat,try saying something like..."Honey...lets talk a little walk through your closet!!" /forums/images/graemlins/blush.gif Be prepared to sleep outside though....
2023 FORD  TRANSIT T250 CARGO VAN (A59914)
2023 FORD TRANSIT...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2006 Ford F450 XL Super Duty Swab Rig (A62679)
2006 Ford F450 XL...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A65643)
2015 VANTAGE...
6' 3Pt Bush Hog Mower (A66408)
6' 3Pt Bush Hog...
TRUCK RAMPS (A64556)
