Bench Grinder - Flexible Shaft
/ Bench Grinder - Flexible Shaft #1
dullpain
Platinum Member
Middle Tennessee
Kubota M5700 4 WD w/ FEL, Kioti CK4010SE HST, 21' Flatbed Gooseneck Trlr.
Want to put a flexible shaft on my bench grinder for the purpose of attaching 4 inch to 8 inch cotton,sisal,muslin polishing pads. Having no luck in finding. Can anybody here help - please!
Don't suggest Foredom or Dremel, they are all too small. Particulars are below
Bench Grinder with a threaded arbor, 1/2 inch x 20 threads per inch, Right Hand threads, 1/2 H.P. , 3580 RPM.
I would like a 48" to 52" flex shaft to attach to this grinder. I need to attach 4" - 8" cotton , sisal, buffing wheels to output end. Buffing wheels will have 1/2 inch hole for attaching to flex shaft. Also would like to have a chuck or collett for using smaller mandrel buffs with a 1/4 inch mandrel.
Any help appreciated
/ Bench Grinder - Flexible Shaft #2
Grainger or McMaster Carr both have them online. /forums/images/graemlins/smile.gif
/ Bench Grinder - Flexible Shaft #3
This is what I use for buffing.Maybe you can do the same. I removed the 1/2" nut and replaced it with a chuck. Works great.All I did was to cut a hole in the out board guard.
good Luck
gugy
/ Bench Grinder - Flexible Shaft #4
Geeze, you should have posted earlier. A month ago, I tossed a 6' flex shaft that my dad used (very little). I've kept it hanging in the garage for 10 years--and finally decided it wasn't worth keeping...............
UGH.
Ron
/ Bench Grinder - Flexible Shaft #5
</font><font color="blue" class="small">( Geeze, you should have posted earlier. A month ago, I tossed a 6' flex shaft that my dad used (very little). I've kept it hanging in the garage for 10 years--and finally decided it wasn't worth keeping...............
UGH.
Ron )</font>
Isn't that the way it always goes /forums/images/graemlins/confused.gif. Wife tells me that I'm a pack rat. But every time I get rid of something, the above statement holds true. Gerard
/ Bench Grinder - Flexible Shaft #6
The next time the wife calls you a pack rat,try saying something like..."Honey...lets talk a little walk through your closet!!" /forums/images/graemlins/blush.gif Be prepared to sleep outside though....
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2021 John Deere S350 (A64126)
2021 John Deere...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
2023 John Deere 8R 310 (A64126)
2023 John Deere 8R...
3pt Bale Spear (A64127)
3pt Bale Spear...
