Behind the pool slope project
/ Behind the pool slope project #1
DJLX
East TN
JD 2210
Here is a winter project that I have mostly completed. It is really the first major dirt digging I have done with my X585/loader and then 2210/loader. The hairyest part of this was the close proximately to the pool fence. The slope really ended at 1 foot from the fence and went from 20 degrees at one end to over 35 at the other. It was difficult to mow with the push mower so required using the weedwacker which I just love using sooo much /forums/images/graemlins/mad.gif Because of this love I would typacally ignore cutting this part and it would tend to get overgrown. The X585 could cut most of it in 4wd except the steepest 15'. Here is a picture of the slope with my 585/johnny bucket at the half way point with a slope of 27 degrees.
Here is the next picture showing the 585/loader taking the first pass
The next shot with some more dirt removed
This picture is the 2210 getting dirty. I traded the 585/loader for the 2210/loader so you are looking a a very expensive 2210 /forums/images/graemlins/crazy.gif The difference in the 2210 loader ability and 585 loader ability was impressive. Taking a big chunk of earth out of this pile was no problem for the 2210 and I have yet to install the the toothbar that I kept from the 45 loader.
Well play time was over and it is time for seed and straw. Just hope it doesn't rain too hard otherwise I'll have lots of green at the fence. I can now drive the 2210 down by the fence without hitting the ROPS. I will still have to cut in the up/down but won't have to worry about driving into the pool.
Final picture. Now all I have to do is get rid of the dirt /forums/images/graemlins/grin.gif
/ Behind the pool slope project #7
DJLX,
Can you comment on how you like the 2210 vs. the X585/Johnny Bucket? I have about 2 acres some with slopes, and I am deciding between the X585 and 2210. The X585 would probably be fine, but for the price difference (including the JB Sr.) I should probably get a 2210.
Though, I am concerned about the 2210 on the slopes vs. the X585. The X585 "seems" like it would be "safer" on slopes since it has a lower overall height. But, then again the 2210 has ROPS.
Any insights you can give would be appreciated.
Thanks
jje64
/ Behind the pool slope project #8
JJE64,
I'll let DJLX respond for himself, but what I think you don't want to do is do what he did; he probably could have bought a 4310 with what he has into this set up! /forums/images/graemlins/tongue.gif
DJLX,
Looks good, but where are all the rocks and clay? If that were a pile around here, at least half the pile would be rocks and clay. /forums/images/graemlins/blush.gif
Cheers
JDFANATIC
JD2210
Put a little water on that dirt and you'll be walking taller with every step /forums/images/graemlins/smirk.gif /forums/images/graemlins/grin.gif
jje64
Here is what I have found so far. Be aware that I haven't used the 2210 for mowing yet but by the temperatures here it won't be long.
The X585 has going for it;
Quiet gas twin EFI that starts easily
Good styling and with the HDAP tires is mean looking!
Doesn't have a ROPS to get in the way while mowing.
Easy operation -just push the pedal and go.
Switchable 4WD on the go. Switchable diff lock
Ability to upgrade to 3 pt/PTO and FEL
Very limited 3pt
One control for loader bucket and 3pt- not good
Johnny Bucket Sr. is a nice addition with limitations but it is around $1400.00 as compared to $2700.00 for FEL
The 2210 has
Diesel (a little harder to start and blows some smoke on startup which is a good reason to have the door open and front of tractor facing it. It is also noisier.)
More tractor-ish styling but easier for me to get on and off.
Same tires as the X series if you want.
Overall the tractor is more noisey than the 585
Easy operation -Select range then push the pedal and go.
3pt/PTO included and is more capable
FEL is much more capable and the joystick is a pleasure to use. Has float that works well.
MMM is easier to remove than 585 I found.
Didn't feel any tippier than 585.
ROPS does hit some branches.
FEL costs less than loader for X series.
Cost for 2210/ 3pt with loader around $13k- $14k
Cost for comparable X585/3pt with loader $14k-$15k
Cost for owning a JD- priceless /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Behind the pool slope project #11
Your 2210 should start instantly. Just switch the starter on with the gear selector (on the HST) in a gear. Hold for a 5 count, then move the gear selector to neutral. Should start instantly, with some white smoke. This is the way I start my 4010, which starts instantly.
I've a 1983 Benz that starts instantly ALL the time. Just have to let the glow plugs do their work for 2-5 seconds in the winter time when starting cold.
There's something wrong, or compression is shot (after A HUGE number of miles/hours, like up around 300-500,000 miles), if a diesel won't start instantly. That's one thing I like about them. Had a 1972 Benz diesel with almost 200k miles that sat for 9 months, with battery stored in basement by the furnace, on 2 sets of timers to keep it charged. Came back, put battery in car, let the glow plugs glow a bit, turned to start: immediate start. This just doesn't happen with gasoline engines left to sit for a spell.
Ralph
/ Behind the pool slope project #12
DJLX,
I was thinking the same thing as Ralph; are you using the cold start system/method he described? For whatever reason it is not covered in the owners manual. As you use it (my dealer said up to 20 sec. depending on the temperature) you will see the idiot lights dim so you know current is being drawn. The tractor should start immediately.
Guys- I was comparing to the X585 which is fuel injection and does start quicker than the 2210. I have tried the glow plug trick and yes I notice the difference but the temps in this area are in the 50-60s so it is not cold. The 2210 still takes a couple of sec to start and blows a second or 2 of smoke.
/ Behind the pool slope project #14
<font color="blue"> MMM is easier to remove than 585 I found. </font>
What is it about the 2210 that makes the MMM easier to remove. I was considering a 585 over the 2210 partially because I thought it would be the other way around. I have a 4310 for loader and 3PT work, so I'm looking primarily for a great mowing machine, but I take the deck on and off a lot.
Thanks,
John
John
This is for taking off the deck as I haven't yet put it back on. This 54" deck is also the same deck I had on the X585. The difference that I see between the two tractors is the 2210 has spring u pins for releasing the rear of the deck as opposed to the x585 which uses a open fork with a stationary pin in the deck. With the 54" deck you rotate the wheels before you drop the deck to the ground and then once you release the pins and raise the linkage the deck rolls right out. On the X585 I had to move it a little front to back to clear the links. It always seem to come out some then I would have to shift a little. It wasn't that difficult but required sliding so really needed to be done in the garage or on a smoth surface. It is harder to explain than to actually do. Hope this helps.
Also I can remove/install the MMM with the loader on, not so with the X585.
2022 CATERPILLAR 299D3 XE SKID STEER (A65056)
2022 CATERPILLAR...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
