Newbie - need input & help please
/ Newbie - need input & help please #21
I would likely be the primary, and my husband would be the secondary.
Then I would definitely consider a decent used tractor 4wd (mfwd, etc). Something like a JD 4300, 4310, 4400, 955, Kioti dk35, Kubota L3901, maybe even a NH boomer or work master (I’d stay away from anything super steer).
On budget, don’t forget to think about attachments you will want/need. They can add quite a bit to the bottom line. Again, shopping for good used stuff just takes time and a little patience.
/ Newbie - need input & help please #22
I apologize for the slight thread drift. Two things jumped out at me, newbie and swamp. You can very quickly get stuck in the swamp. Be very careful anytime you near the swampy areas. At the first sign of softness, back up. A big heavy tractor with 4wd can and will get stuck, and stuck bad. Be careful out there.
Even with my "glorified lawnmower" (BX24) I was amazed the first time I was in mud and had all four wheels spinning and no movement.
Doug in SW A
/ Newbie - need input & help please #23
Send a private message to me. I'll give you a phone number of a woman in Stockbridge who has been thru everything you described, solved all her needs with a used modern tractor and would give you the best advice. She deals with horses, sheep, hay, gardens, wood/logs, fences, and dogs.
  • Good Post
Reactions: D&D
/ Newbie - need input & help please #24
A Kubota L2502 would work well for your needs and wouldn’t break the budget.
/ Newbie - need input & help please #25
My 2 cents and I hope they help. I have 10 or 12 wooded acres with only about 1 1/2 acres cleared. I use a 1980 Yanmar YM2310 tractor that has an after market loader for all my tractor duties. It has, apparently, a 27 HP engine with 23 HP PTO. It has a 5 speed primary transmission that feeds a 3 speed with reverse secondary transmission. The secondary transmission has an automatic wet clutch so no stepping on the clutch is required to change speeds or to reverse. The main transmission can only be shifted when the tractor is stationary. But the secondary transmission can be shifted while in motion. This is a HUGE convenience. Yanmar calls this feature "Power Shift".
I also have a Case 580 CK Backhoe complete with a front end loader. It has a feature called "Shuttle Shift". Similar to the Yanmar it does not require using the clutch. But it is just for forward and reverse. When moving dirt this feature is super useful. SUPER USEFUL.This machine is much bigger and heavier than my Yanmar. I bought it to install a septic system when my house was built. When I bought it I had never even sat on a backhoe and knew nothing about septic systems. In the end the county used my septic system as an example for how a septic system should be done. So even a neophyte can learn and do a good job.
I used the backhoe to dig many ditches for power, phone and water. It doesn't have a thumb and I really wish it did. REALLY.
Because you have so many more acres to take care of I think you should go with a 40 HP machine that is 4wd. My 27 HP machine could do the work but it would take much longer. You also need a machine with a front end loader. They are super useful. I have a Ford 9N tractor and while it is a good machine that has served me well it does not have a front end loader and so I just don't use the thing anymore.
I put in a road through my woods with my backhoe even though it is not the best machine for the task. But it did the job. I used the backhoe digging out trees and getting unstuck.
If I was you and thought I might be needing to put in ditches for water and power, etc. I would get a 4wd tractor with a backhoe. With a thumb. And a Shuttle Shift. And 40 HP or above.
Anyway, my 2 cents from a former neophyte.
Cheers,
Eric
/ Newbie - need input & help please #26
Buy a good tractor with a front end loader. The rest of the equipment you can pick up over time. Check out FB Marketplace or Craigslist for good deals. They are there you just need to be patient. Don't send anyone money until you have the implement on your trailer. If people don't like it just tell them that that is the way you do business. Don't be scared to walk away from idiots.
Several have mentioned a backhoe. If you sit down and do the math of buying vs renting a small mini hoe you'll probably find that renting is a lot cheaper. Also you can buy a new mini hoe for considerably cheaper than a new hoe attachment for the tractor. Then you don't have the issue of removing the hoe to do some rotto tilling etc. and then reattaching the hoe just for some little job you forgot to do.
/ Newbie - need input & help please #27
If you don't want to wrap a chain around a log to pull it
you can get one of these:
Claw Hook,Log Lifting Tongs, Heavy Duty Grapple Timber Claw,Lumber Skidding,Log Lifting (21")$43.99​
willy
/ Newbie - need input & help please #28
Your John Deere and Kubota cost more than the other brands so shop around and test as many tractors that
you can using all the controls to see if you can find a
tractor that has the controls were you are comforrtable
with.
willy
/ Newbie - need input & help please #29
If you take the invites to go and visit the Brighton and Stockbridge peeps come to Howell as well and you can take my Kubota L3940 w grapple for a spin. 39hp, 4wd, ~4500#. Agree about the mud; I have lots sometimes and have learned to be careful...
  • Good Post
Reactions: D&D
/ Newbie - need input & help please #30
We have 14 acres of pasture with a few acres of woods and keep 3 horses. I would recommend a tractor with at least 40hp so you get enough power and weight to lift safely with the FEL. Plus, you have the power to use 6' implements like a cutter or tiller. We started with the NH TC40DA with 40hp for mowing, dirt work, and dragging the arena. It is my and my wife's go-to utility tractor. We are now up to 3 tractors, 2nd was a Workmaster 75 75hp with a cab for me to do mowing and grapple work.
I just bought a 3rd tractor, a NH 25S 25hp for mowing turnouts and under the trees, also small dirt work like filling in around the stable doors as the horses wear a path going in and out. It is handy but is too small to do the things the TC40DA does. While some say that a small tractor can do everything a big tractor can do, it just takes longer, I have found that is not true. I would have been out of luck if we had started with a small tractor.
/ Newbie - need input & help please #31
with.
willy
Ya they do cost more, but they also generally have better parts availability. That's important too.
/ Newbie - need input & help please #32
Almost 20 years ago we moved onto our 10 acre patch. We got a new Kubota tractor with a front end loader, 50+ hp and a mounted backhoe. Costly, but so far we can do anything and everything on our own schedule, and only needed a dealer once for something that was simple but I didn't have the time. Parts - rarely needed - we buy online.
Originally I thought it was more than we needed, but as we age it becomes more and more important. If I had to do it now, I would buy the same sort of tractor, but in 25 to 40 hp and yes definitely with the backhoe. We use the hoe for lifting and placing things more than for digging.
/ Newbie - need input & help please #33
Here's my two cents. One thing you constantly hear on these tractor groups is to buy one size larger tractor than you think you need. I say hog wash! It doesn't matter what size tractor you buy, you will ALWAYS find a task that it can't do. It doesn't sound like you have a NEED for a lot of HP but you do have a need for a decently weighted tractor. You can do lots of things with less HP by just going a bit slower.
I have 20 acres that we work pretty hard. EVeryhing from brush clearing, timber clearing, trail making, tree planting, food plot and garden tilling, etc etc etc. I purchased a Kubota L2502 and it does EVERYTHING I need it to and does a fine job of it. You can pick up used Kubota L2501 HST's which are basically the same tractor for around $16-19K with very low hours on them.
I have my opinions of the Korean tractors based off the research I have done and personally, I would steer clear of them. I would go with one of the big makes first. A good dealer is VERY important and I can't stress that enough.
/ Newbie - need input & help please #34
I normally do not hang out in this section as Folks here will tell you that you need the biggest tractor or what they bought. If I were you I would get a 4wd 60-75 hp utility tractor with a shuttle shift transmission and a loader leaning towards a Kubota M6800 as it has a locking front differential to help in the mud. But that is not the right tractor for you, it is for me though. Below is my opinion, based off of running tractors from subcompacts to large 4WD articulated at home, in a turf maintenance enviroment and farming in three states (all 12 hours apart).
I would definitely get a hydrostat transmission. The learning curve on them is much shorter than a geared. I am not a fan of hydrostat transmissions for personal reasons, however they are the way to go for a new operator.
John Deere 430 (used 2002 model, no cab, 1600 hours, fork blades, snow plow included)
Kioti CS2520
Yanmar SA series
Mahindra emax 20S
John Deere - something newer like a 2025R
John Deere 1026R (used 2012 model)
Kubota BX2380 or BX2680
The JD 430 is a lawn mower not a tractor and is not comparable to the other machines on your list.
The "BX series is a glorified lawn mower". Yes it is the size of a lawn mower, yes its loader capacity is small. But it is much more capable than a lawn mower, the category it falls in is "sub compact tractor".
It's a 1949 Ford 4N but I don't think a loader can be used with this.
I have an 8N and can say they are terrible with a loader as they take 50 plus pounds to turn the steering wheel.
I am going to keep saying BX but what I really mean is sub compact tractors. See my comments in red below.
Tasks to be done with the help of a machine:
clearing overgrown fields Larger tractors have more lift and can push / mow over larger brush. 30+PTO hp is nice However once its clear a small bx can keep it up if mowed frequently. You can clear with a BX but you will have to do lots more hand cutting and cutting to smaller sizes.
clearing some underbrush areas Smaller tractors are more maneuverable and agile. A BX with a 4 or 5 ft brush hog can run a circle around a tree
moving dead/cut trees Large tractor with high lift capacity. A grapple makes this job soo much easier. However for a grapple you will need third function hydraulics on the loader. Grapples are also $$.
maintaining gravel drive Unless your driveway is crazy steep, washes out terrible or is poorly constructed a small or big tractor will do just fine. You will want an implement such as a land grader scraper, back blade or box blade to use.
snow removal as needed (a handful of storms, nothing too horrible) A small tractor will move less snow but still can move it. I used a BX in college and could push piles of snow that were three feet tall hundreds of feet with the little 4' blade on the front. However the bigger 45hp tractors with 8' blades could move move even more snow.
organization/movement of hay bales (sometimes up high) Depends on how high or how heavy. Larger tractors have taller lift and larger capacity loaders.
tilling for planting Any size tractor can do this. I have tilled with a 4' tiller on a BX and with a 40' disc on a 425 hp articulated tractor. Depends on how fast you want to till.
movement of barn pen/goat bedding (this is the hardest one) Not really the hardest, any of the tractors your looking at will move manure just fine. A manure grapple helps, but a bucket can do it too. A smaller machine might be nicer depending on the room you have to work in. Less room and the smaller tractor will shine. I would have not problem cleaning manure with a BX. Most of my manure cleaning with with a large backhoe or a skidsteer with a grapple in a feedlot.
A loader is a must based off of your chores. It significantly increases the capability of a tractor.
We own 13.5 acres in Michigan. 4-5 of those acres are swampy lower level creek lands. The remainder is high, mostly field and a tiny bit wooded.
Any tractor size will work for your needs. There is no perfect size. Most folks here subscribe to "bigger is better" and "buy what I have its the best".
TBN is a great tractor info source, but at times some tend to go big HP size because maybe speed is their priority , but hobby farm budget and time can manage with small effective tractors too.
However I believe that everyone's needs are unique and there is no perfect tractor size. I know that two weeks ago I was filling in a ditch in a ravine and barely had room to turn my tractor to dump in the ditch a BX would have been perfect as it would have been small enough to maneuver. Last week I was mowing a piece of property that had not been mowed in 10 years and I was wishing I could have borrowed a friends 120 hp tractor with a 8' brush hog as it would have mowed more down than I was able to with my smaller 45 hp tractor (plus the air conditioning would have been nice). Also note that horse power (HP) is rated in two places engine and PTO (Power Take Off)
As I've been researching and reading, I'm seeing that horsepower is probably #1 on the list followed by the weight of the machine as #2.
There is no #1 consideration, it is all about balance. I would determine what size of tractor I need then get something with hp on the higher side. No one ever had to much horsepower. Weight is not that important, what is is the comparison of weight to loader capacity. A very strong loader on a light tractor will require significant counterweight. A heavy tractor will sink in wet ground quickly. You can always add weight to a tractor but you cant put one on a diet. So determining what you need done, how quick it needs done, and your budget then drive what you need for size of tractor.
I worked for a tree farm that had a kubota 7500 it had 21hp and we mowed with a 5' brush hog. Everyone here would tell you your nuts if your going to mow 75 acres with a 18 pto hp tractor. It took a darned long time but the deck of the mower stuck out so it was easy to get under the trees and the small tractor was very manuverable. I also worked on a farm that had 180 acres of trees. I mowed it with a Case 5240 100hp tractor pulling a 7' brush hog. I could mow darned fast but it was a real !@#$ to turn around at the end of the row. I also could mow over 3" junk trees without slowing down. Each one had advantages, most folks here would not recommend either for this job. A 75 hp small framed tractor with a 8' dual spindle brush hog would have been perfect. The reason I told this story is that balancing needs is critical to finding the right tractor. Both of these tractors were the wrong tool but still got the job done.
There is one guy here who only focuses on weight, his advice is wrong most of the time. I have an Industrial tractor it is really heavy and the loader is really strong but it is not a well balanced machine (but was cheap). Others focus only on HP or brand there advice might not be right for you either.
Go to at least your 3 nearest dealers and get some sitting in the seat type experience.
This is great advice.
Our tasks can be delayed, we have someone or we would need to have a dealer.
The dealer is just as important as the tractor. See what they have for a repair shop, don't be turned off my messy / dirty shops, it means their mechanics are fixing stuff, not polishing the floor. Is the shop willing to pick the tractor up or do they have a mobile mechanic? What are their hourly rates? Also how far torn down is the equipment that they are repairing, some dealers can handle major repairs, whereas others anything other than an oil change befuddles them.
I was in the ag parts business, I have had way to many calls from dealers looking for parts for their Bison, Hinimoto, Long, Tafe, Satoh, Iseki, Mitsubishi, Belarus, Leland, etc. These were all smaller companies that are either no longer in business or have exited the tractor market. This is why I avoid the less common brands. It sucks to have your $XX,XXX tractor stranded and worthless because you cannot find a $500 hydraulic pump or some other part. The big names in tractor's are Case International, John Deere, Kubota, Massey Ferguson, and New Holland.
Have fun sorting out opinion vs fact and finding the tractor that you need!
/ Newbie - need input & help please #35
Good luck with your endeavor.
When I bought my Kubota I was a newbie as well. I wound up with the B series, a B2320 with a loader, box blade and mower.
When I was talking to the dealer he suggested I look around online for "tractor package deals".
And I am going to suggest you do that as well.
He told me that he would beat any deal that I could find from other dealers, and he did.
I am sure other mfgs. may also offer deals that would suit you.
Many of them include trailers which I think would be a good addition to your purchase.
First of all it allows you to take the tractor in for service if necessary.
And when that isn't an issue....you have something that can haul everything on your property from point A to point B.
It will come in handy when you need lumber or moving firewood etc.
Backhoes have been mentioned here as well. They will add quite a bit of versatility and ability to your tractor....not to forget the "quite a bit" of extra cost to add one to the machine.
Many people opt for a mini-ex instead of a backhoe on their tractor....you can often find one, albeit an import for considerably less than outfitting your tractor with an attached backhoe.
Just keep doing your homework and ask questions.....that's the most important part of your project.
And again, best of luck to you.
/ Newbie - need input & help please #36
Did you hear that John Deere is closing door and moving
to mexico??? What impact will that have on parts????
willy
/ Newbie - need input & help please #38
willy
None of the local dealers are moving to Mexico. Just one of the manufacturing facilities.
Parts are still being made and sold.
/ Newbie - need input & help please #39
Remember one thing.
Some of the items are a one time project.
You will clear the overgrown fields once...then maintain them
Same with the underbrush, moving dead trees and other projects you may have missed.
Once those are done you may realize you need a bit less of a machine to maintain what you have.
And for the big items on your list, you can certainly rent a machine for a while to take care of all of it.
Then after you see what projects become normal routine.........you can get a tractor to fit those needs.
/ Newbie - need input & help please #40
Good Morning Sportsman,
I did mention the weight of my old Massey Ferguson 1040 in a previous post ! I don’t think weight is the most important thing when selecting a tractor but it is a factor ! I would put my tractor with AG tires against any similar rated HP machine on dirt or in the field and it will out pull that machine ! Physics tells me that ! JMO !
  • Good Post
Reactions: D&D
90in. Work Bench (A65640)
90in. Work Bench...
6ft Teakwood Cowboy (A65583)
6ft Teakwood...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Dodge 5500 Bucket Truck (A63689)
Dodge 5500 Bucket...
Pallet of Mini Excavator attachments (A62679)
Pallet of Mini...
