Battery powered chainsaw
/ Battery powered chainsaw #1,181
It's all about the chain...correct? A sharp chain
running at the right rpm & torque will cut properly.
Yesterday I cut an 18" at base cedar with my Greenworks 18" 80v saw (wished I known about the one for sale I would have bought it for a spare). Checking different sites of all things Walmart had a Greenworks 80v weedeater on sale way less than a spare battery so I have 2 batteries, 2 chargers (one I can have in truck on an inverter). One battery did the job cutting it all up though.
It's so easy topping off bar oil reservoir and unlike gas so quiet I can hear if something is going on like a limb falling or barber chair, etc.
I'm not an environmentalist but a variety of tools, each has a purpose whether gas, air pneumatic, corded AC, battery, etc.
Then I used a Dewalt 20v pole saw thinking wow...if we had all these choices growing up in the 50s-60s. We had one David Bradley gas saw and everything else manual hand saws and tools.
Fantastic convenience!
/ Battery powered chainsaw #1,182
What lithium-ion battery existed in the late 1960's? The first commercially-available Lithium Ion battery was released by Sony in 1991. Even the underlying science behind them didn't start until the late 1970's, and the first working lab models mostly happened in the 1980's.
Lithium Sulfer packs about 4x the energy per pound of Lithium Ion, and prototypes have indeed been built and tested. This is likely the next technology to see full-scale production. Lithium Air, sodium-ion, and solid state (versus liquid Li-Ion) batteries are all at various prototype stages.
Yes, per pound or kg, gasoline is way ahead. Something like 12 kW/kg versus 500 W/kg. Even after considering the low efficiency of a gasoline engine, you're netting something like 8x better energy per pound from gasoline.
It's not just the greenies. I suspect most buying battery saws are more interested in the convenience factor, than any environmental factor.
Not sure I follow you, here. Gasoline can't be re-used, but Li-Ion batteries are happy through many thousands of recharge cycles. Seems like a useless comparison. You'd do better to look at TCO of the equipment, all factors considered.
I love my Cummins Diesel powered Ram. I love my Stihl 500i.
However, I know deep down inside, a properly battery powered electric Ram would make more torque than a diesel Ram. I also know that once battery technology takes 1 or 2 more steps towards being lighter and longer lasting, it might spell the end of the internal combustion engine.
I can’t see why anyone would fight this?
You’ll charge your truck at home.
You’ll be almost done with dealing with all types of fluids, oils, fuels and their disposal.
Your truck will become a portable, drivable “power station” for electricity.
Your electric saw will have more torque and be quieter than I-C.
I’m “all in” on the best of the I-C engine for now, but I hope we evolve and improve technology. I bet we could have trucks that have 1,000 ftlb of electric torque and saws with batteries that last an hour, if science/technology continues
/ Battery powered chainsaw #1,183
The military had lithium batteries in Vietnam and I’m pretty sure nasa used them in moon landing as well. The batteries are reusable but the cost is still a factor. A gas saw can work all day for $10-15 of gas where the battery saw would need several thousand dollars of batteries to do the same job. Even if you had access to electricity to recharge you’d probably still need at least 3 batteries at the cost of several hundred dollars each.
/ Battery powered chainsaw #1,184
The way you talk about this I agree with very much so and its also the correct way for those that like it for environmental reason to speak of it as well. The mistake of the EV and battery group was to say it was exclusively for the environment. If you simply tell people what electric will mean for their bottom dollar and efficiency, they are much more likely to "buy in."
/ Battery powered chainsaw #1,185
Ye have little faith in the future of new technology
I just don’t see things changing dramatically enough to actually make batteries feasible. And I don’t fear change I dislike the government trying to ban the alternatives. When battery trucks can actually haul the load the consumer will buy them on their own. Technology moves fast at first and not so much after that. Is your smartphone radically different from one 5 years ago? One from 5 years before that is radically different. Is a flatscreen tv any different from one 5 year ago? The military is flying decades old jets with upgrades. Is your newish Cummins drastically better or different in design from a 20 year old Cummins? The batteries don’t just need to be a little bit better they need to be a completely different technology at a drastically lower price. And the problem is batteries not electric. Electric motors have been doing serious work for over a century.
/ Battery powered chainsaw #1,186
Electric power has some inherent good possibilities.
But it is going to take engineering to get past the know it all bean counters and provide working drive systems. Yes the electric motor can provide 100% torque immediately however having an EV my wifes Equinox and an electric mobility scooter and having tested an electric utv. One conclusion I've come to is that while the power may be available it is not usable without proper gearing. EV's developed for heavy loads and low speed lugging as well as high speed traveling are going too need a "transmission" of some type, maybe a simple internal two speed or a brake able planetary to have the torque multiplication to move heavy loads at low speeds and not over heat and burn out motor windings or trip thermal sensors and shut you down and still be able to provide the higher speeds. Using variable voltage to provide varying torque is counter productive in low down slogging.
/ Battery powered chainsaw #1,187
100% agree
/ Battery powered chainsaw #1,188
Combined we have 95 acres of Christmas Trees in the family and switched to Stihl AP battery saws about 6 years ago starting with one and now have 4.
The gas saws rarely come out and the seasonal gas saw issues are no more and nighttime Christmas season operation no longer a noise issue…
So far no battery issues and the newer AP batteries have more capacity and interchange.
I was debating on buying one when they first came out and had the ghostbusters battery backpack. The family were planning to surprise me for Christmas because they thought it would be better on the trees since “being battery powered the trunk base wouldn’t be covered in petroleum products”.
Say what? Just because it’s battery powered doesn’t mean the chain doesn’t require bar oil.
I think that idea in and of itself, caused me to wrap a surprise birthday gift to myself a few years later with the Milwaukee cordless. Ive used the Makita saw, and can say it’s just as nice, but I don’t own any Makita 18v tools, batteries or chargers.
/ Battery powered chainsaw #1,190
Lithium batteries used during moon landings? When? Lithium batteries don’t really work in cold temperatures, so would need substantial additional heat energy in space. I’m quite certain they weren’t used in the Apollo missions to the moon, if that’s what you’re referring to.
How do you calculate several thousand dollars of batteries needed to do the work of one gas saw? You realize one battery can be charging while you’re using another, right?
/ Battery powered chainsaw #1,191
I think he means batteries will need replacing after hundreds of charges (they wear-out)
But let’s keep it real: ICE chainsaw Pistons & cylinders need replacing, too.
I’m not sold on today’s versions of battery chainsaws, but I am optimistic for what the future holds for battery powered saws.
/ Battery powered chainsaw #1,192
If I have to spend the day cutting trees gas is the choice. Recently a tree fell across our driveway and I used both gas & battery, especially when one gets pinched! I hope gas & diesel will be around for a long long time.
I just looked up corded (120 VAC) chainsaws.
I have two here and they're very light and handy of course near a power source.
Recently I've been considering a battery riding mower like a 60" zero turn. I see ones that claim 5 acres on a charge.
I need that to add to my 4 other mowers!
/ Battery powered chainsaw #1,193
If you’re bucking firewood rounds one after the next the run time of those batteries is literally a few minutes and they cost like $300 each. I didn’t look up the charge time but I don’t see how you could get by with any less than 3 batteries and 2 chargers. That’s for 1 saw operator and with access to electricity. Bring 2-3 saw operators and take away the electricity and the battery logistics is stretched to ridiculous levels. One 5 gallon can of gas keeps a whole crew working the whole day. Your cold temperature comment brings another problem. What season do most people cut firewood in?
/ Battery powered chainsaw #1,194
You just painted the best case situation for a gas saw, and the worst case for a battery saw. Do you not see that?
One possible situation out of a thousand.
What’s your actual experience using electric chainsaws?
/ Battery powered chainsaw #1,195
Stan Wittingham built the first lithium-ion battery prototype in the late 1970's, ten years too late for vietnam or Apollo 11. And his design wasn't manufacturable or safe... that took another 10 - 15 years.
There were non-rechargable lithium battery technologies before lithium ion, we've all had lithium watch batteries for example, but that's a different animal.
"Several thousand dollars"? I've never shopped electric saws, but I just checked the Greenworks site, and they seem to charge $60 - $130 for most of their chainsaw batteries. Re-charge time is faster than typical discharge time, so seems one spare battery in addition to the one that comes with the purchase of a saw, is going to suit those with access to power just fine.
Even if the battery had a lifespan of only 1000 recharges, it works out to pennies per refill, versus more than a dollar for a third of a gallon of fuel mix. I think that over the lifespan of the product, battery is going to win on cost.
That said, replacement cost on any of my gas saws is presently at $1000 - $1800. The insignificant cost of the fuel isn't even a factor in my purchase decision.
What popular chainsaw batteries cost "several hundred dollars each"?!?
/ Battery powered chainsaw #1,196
The battery on the 82v saw compared in this thread against the 500i cost over $300. I have no idea how long it takes to charge but i know my 8ah dewalt and Milwaukee batteries take a while to charge and that one is considerably bigger. I’m not arguing the claim that a battery chainsaw is useful. For the average homeowner that doesn’t heat with firewood it’s probably fine. I’m arguing the idea that we’re anywhere close to ready to toss the 500i and ban combustion saws.
/ Battery powered chainsaw #1,197
Battery saws are really nice for pruning and cleanup around home. I would never go to woods to put up firewood with one.
/ Battery powered chainsaw #1,198
That’s all true as of today, but the advances they’ve made in the last 5-10 years are pretty good.
All that said, I have zero electric chain saws.
They just aren’t there yet, but it’s probably coming.
/ Battery powered chainsaw #1,199
Agreed. The 500i is the present culmination of 60+ years of chainsaw development, it'll be awhile before any battery saw is a true replacement for a saw like that.
But that saw is also way outside the price range or target customer for most battery saws. For many of the tasks that most homeowners or firewood cutters do, I think the battery saws can be a pretty good fit.
And like Hay Dude said, I see the number of applications in which the advantages of a battery saw might outnumber a gasser only increasing, in the years to come.
One interesting thing to ponder is that California is always the first to do things like outlawing 2-stroke engines, while I'd bet most of the 500i's sold in the US are probably going to pro cutters in the PNW. Are they going to shoot themselves in the foot again, before the tech is ready for such applications?
/ Battery powered chainsaw #1,200
Even if we lowered the standards to a 261 at 1/3rd the cost is there a battery saw that could buck an entire tree in the same timeframe? The battery saw also has the weigh and cost similar otherwise you might as well bring the 500i back.
PALLET OF MISC MOTORS AND PARTS (A68842)
PALLET OF MISC...
2018 KENWORTH T370 LUBE TRUCK (A65057)
2018 KENWORTH T370...
2015 INTERNATIONAL LONESTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 INTERNATIONAL...
2010 INTERNATIONAL WORKSTAR 7400 BUCKET TRUCK (A67714)
2010 INTERNATIONAL...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
