Bathroom Re-model concrete foundation
/ Bathroom Re-model concrete foundation #41
That's an interesting bathtub. Do you walk into it, sit down, close the door, then start filling it up while sitting there? How long does that take? I guess the same happens when you are done? you open the drain and wait for the water to go away before you can leave it?
Yes....that's the process.
Fills pretty quick. Has 3/4" lines that connect directly, compared to the typical 1/2" lines on a shower valve, which are further restricted by govt mandated low flow shower heads.
On the drain, it has a power pump motor + the typical tub drain. Will drain in under a minute. You're still plenty warm from the bath by the time it's done. Has two other motors for water circulation and an air pump.
/ Bathroom Re-model concrete foundation #43
That's a lot faster then I was thinking.
2009 TRAIL KING PNEUMATIC TRAILER (A67714)
2009 TRAIL KING...
2014 John Deere 855E XUV (A64912)
2014 John Deere...
Mower King QA 72" Rototiller (A64912)
Mower King QA 72"...
6 wheels to fit a CAT 120G (A68134)
6 wheels to fit a...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
