Bathroom Re-model concrete foundation
/ Bathroom Re-model concrete foundation #41
That's an interesting bathtub. Do you walk into it, sit down, close the door, then start filling it up while sitting there? How long does that take? I guess the same happens when you are done? you open the drain and wait for the water to go away before you can leave it?
Yes....that's the process.
Fills pretty quick. Has 3/4" lines that connect directly, compared to the typical 1/2" lines on a shower valve, which are further restricted by govt mandated low flow shower heads.
On the drain, it has a power pump motor + the typical tub drain. Will drain in under a minute. You're still plenty warm from the bath by the time it's done. Has two other motors for water circulation and an air pump.
/ Bathroom Re-model concrete foundation #43
That's a lot faster then I was thinking.
New/ Unused Plate Compactor (A61166)
New/ Unused Plate...
2010 Scag STT52V-27CH 52in Zero Turn Mower (A61567)
2010 Scag...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2016 Ram 4500 Crew Cab Landscape Dump Truck (A61568)
2016 Ram 4500 Crew...
2010 Gorman-Rupp T-Series T4A605-F3L Towable Trash Pump (A61567)
2010 Gorman-Rupp...
New/Unused Wolverine Quick Attach 3 in 1 Frame (A61166)
New/Unused...
