Bathroom Re-model concrete foundation
/ Bathroom Re-model concrete foundation #41
That's an interesting bathtub. Do you walk into it, sit down, close the door, then start filling it up while sitting there? How long does that take? I guess the same happens when you are done? you open the drain and wait for the water to go away before you can leave it?
Yes....that's the process.
Fills pretty quick. Has 3/4" lines that connect directly, compared to the typical 1/2" lines on a shower valve, which are further restricted by govt mandated low flow shower heads.
On the drain, it has a power pump motor + the typical tub drain. Will drain in under a minute. You're still plenty warm from the bath by the time it's done. Has two other motors for water circulation and an air pump.
/ Bathroom Re-model concrete foundation #43
That's a lot faster then I was thinking.
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
2017 CATERPILLAR 289D SKID STEER (A65053)
2017 CATERPILLAR...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
Saddle Tanks (A65640)
