Barndominium/Shop or "real" House?
   / Barndominium/Shop or "real" House? #31
I didn't look at your plans because I would have to download them first, and I didn't want to do that.
In my opinion, two buildings are better then one. Having said that, I built my house with an oversized garage that has been my shop for the last 15 years. It's worked out OK, but it's also become a bit of a storage area that I'm always struggling to get stuff out of so I can work on a project. It's convenient to go from the house to the shop, sound and smells have never been an issue either. But the living area next to it is small and I want more space, so I'm in the process of building a three car garage next to the shop and converting the existing shop into a great room. It's been a long, expensive, drawn out project without any end in sight. I also have stairs going for two bedrooms and a full bathroom. My master bedroom is downstairs. When my wife had knee replacement surgery, it was impossible for her to go up the stairs. For that reason alone, I would not build a home that is upstairs.
Once my house project is done, and a dozen other big projects are done, I'm going to build a full sized, as big as I can, shop off to the back of my fenced in dog yard. It will have a long leanto for storing trailers and implements, and be as big as I can afford to park everything under roof and also have space for all my tools. One of the big advantages to having a separate shop is being able to add to it, store and park stuff all around it, and have multiple ways to get into it. Having it attached to your home just makes it an oversized garage.
If you are going to finish the interior walls of a building, then the most cost effective way to build that building is by stick framing it. If you go with posts, or metal, then you are paying for the walls twice when you add the framing for the sheetrock.
With every home design, if you start out with a rectangle shape of the building, you are at the most cost effective point. Mobile Homes are brilliant in their designs for the maximin cost efficiency. Every person that designs their own home for the first time gets it wrong. Usually it's really wrong!!! Since I didn't look at your design, I cant comment on what you came up with, but what I would suggest is talking to your builders when asking for a bid, and ask them for their input on how to save money in the layout and finishes. Very little things can cost a huge amount of money without any benefit to the livability of the home.
Make the shop as big as you can afford, as tall as possible so you can have as big a door as possible. 10x10 should be the minimum size for a shop door. 12 foot wider is a lot better!!!! Plan the shop so you can add on to it by making it longer in the future, and add leanto's to the sides of it later on. This gives you a building for minimum money so you can focus on the house. Build a 3 bedroom, 2 bathroom house that will add value to your property so you can get the most out of it when you sell it in the future. Even if you plan on dying there, and you are 100% positive that you will never sell the place, you have to also know that life surprises you and things happen. Sometimes it's an unforeseen opportunity that comes up, other times it's not what we want, but we're forced into selling and moving somewhere else. The better you make it now, the more you will appreciate it later.
   / Barndominium/Shop or "real" House? #32
The cost is minimal for a basement VS a crawl space. I'm guessing in NY you have to put in a foundation that's below frost level. That'll be around 4' deep. I'm also guessing you have to put in a concreted floor with radon remediation. At the least, a vapor barrier would be required. The only added cost at that point is an additional 4-5' of concrete wall and maybe a 3-4" floor. It's very cost effective to basically add an additional footprint the same size as the 1st floor.
While I agree with your math that the basement is cost effective if you need the living space. Then we are back to the stairs used on a daily basis.
Your first sentence is simply wrong.
Maybe I am still too young yet, but I have used stairs daily my entire life.
I did put thought into an elevator in my Barndominium design just in case in my old age it becomes an issue, however, I currently do not see stairs as an issue.
For those who don't want to download pdf's (I don't blame you).
   / Barndominium/Shop or "real" House? #35
Oh don't misunderstand. I'm fine with you using stairs. What I'm debating is spending money to create the need for stairs to living area that's not used. Or rarely used. An unfinished basement would be an example. If you need the space, a finished basement is cheap cost per square foot. But it's not free or minimal cost.
I admire your thoughts of dying in your build. We intend to die here as well. We aren't pessimists. But we try to be realists. The percentage of humans in their last ten years of life that handle stairs is very small. So we avoided them. We even used low thresholds in our exterior doors. No doors or thresholds entering our showers. Showers that you can enter with a wheelchair. No doors narrower than 36". Hallway 48" wide.
I am very active at 71. When I'm 81 I'll PM you and let you know how I'm doing. :)
My father was extremely active until he was 85. He ran all of my equipment, did a lot of bullwork with me at my lot, firewood, you name it. My lot was fully wooded when I bought it, with his help I dug two ponds, lots of logging, etc. He had 3 bad years of strokes from age 85-88 and that was it. I hope to be as active as he was at an advanced age...
   / Barndominium/Shop or "real" House? #37
My father was extremely active until he was 85. He ran all of my equipment, did a lot of bullwork with me at my lot, firewood, you name it. My lot was fully wooded when I bought it, with his help I dug two ponds, lots of logging, etc. He had 3 bad years of strokes from 85-88 and that was it. I hope to be as active as he was at an advanced age...
Sounds like you come from good genetics. I hope you are as fortunate as he was. :cool:
   / Barndominium/Shop or "real" House? #38
A couple of features we added that even the builders have liked:
A separate mechanicals room with direct access to the outside. That way, repairs and maintenance crews can come and go with tromping through the house.
A motion sensor light in attic (we don't do basements around here, but I would put one there).
Single slope roof. Fewer gutters to clean.
   / Barndominium/Shop or "real" House? #39
It looks like you've given a lot of thought to both plans. My first comment has to do with stairs also. The barndominum has been discussed with option for an elevator. The A frame however has more stairs and would be more of an issue to retrofit with an elevator or stair lift of some kind. I'd level the floors so fewer stairs would be needed. It seems to be a split level house.
If I were building your barndominum I would rearange the bathroom by swapping the bathtub and toilet/sink and I'd put in a window overlooking the shop mostly to get more light into the house.
From my understanding, due to fire code no windows would be allowed between the shop and living space.
I did have a design with a breezeway like others have suggested, however it just added cost, made the site work footprint larger etc...
I just sold a house with an attached garage and yes fumes can be a thing. As far as fire in terms of insurance, I'm not sure this barndo would be any different than a house with an attached garage. Insurance might cost a bit more but I don't think it is uninsurable...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
New Holland C345 (A50120)
New Holland C345...
NISSAN MU1F2A25LV WAREHOUSE FORKLIFT (A51243)
NISSAN MU1F2A25LV...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
2014 Genie GTH844 Telehandler (RIDE AND DRIVE) (A50774)
2014 Genie GTH844...
