BARN going up
/ BARN going up
Rox - just so ya know. Chainsaw is a living, breathing, Good friend of mine. He helps me work on the barn all the time.
/ BARN going up
As promised, this is how I get subfloor up on deck. Welded this frame together out of scrap. Really saves a lot of work. Should work well for lumber to frame roof as well.
/ BARN going up
Up on top.
/ BARN going up #65
That's a pretty nice looking lift arm. I'm looking @ making one soon but have not decided on the tube size or length.
What are the dimensions on yours?
/ BARN going up #66
Once again you show us something clever. That's a very nice way to matarials and work by your self!!!!
Eddie
/ BARN going up #67
I have a project coming up that is going to require putting some 4 X 8 sheets on a roof. I have already downloaded your pictures. Great project. /forums/images/graemlins/cool.gif
/ BARN going up #68
Do you have additional pictures of your fel boom posted on the site? I'd be interested in making such a beast and would like to know what size/type steel you used. Are you having any problems with twisting? ... Scozz
/ BARN going up #69
Nice call on the Advantec. That stuff is awesome. I left a sheet out on my deck for about four months in the snow and the rain and it's still perfectly square and flat. It's a bit more $$, but way worth the cost....blows away standard plywood for subfloors and now they're using it as roof sheathing. Excellent product.
/ BARN going up #70
dull, That's KA! Nice job on the hoist and the A-frames. I'll keep this post in my favorites for when I build my barn.
/ BARN going up
Scozz - sent you a PM
JimM - Thanks for the info on the AdvanTech. Swore I would never use OSB, instead of Plywood. Although this appears to be OSB on steroids. Lumber salesman talked me into it , and it appears to be as advertised. Stays flat and true, easier to install than plywood tongue & groove. So far impressed with the product. Also feel free to steal any of devices/ideas that may work for you. I have about one or two original ideas every decade and some of them even work!!!
/ BARN going up
SLOWWWWWW !!! Hope to get going again soon & will post progress.
/ BARN going up
Getting back to a little more work. Walls going up in loft to support Gambrel roof.
/ BARN going up
Roof framing going up.
/ BARN going up
Drive thru shed roofs going on.
Pics of Metal next week , weather permitting.
/ BARN going up #78
Very impressive barn your building!!! I love the amount of detail and craftsmanship that your putting into it.
Thanks for the pics and keeping us updated. One day I'd love to have one just like it!!!
Eddie
/ BARN going up #79
Advantec is the only way to go. I had so much water and snow in my house you wouldnt believe it. We had one of the snowiest winters in the northeast when i started framing. I resorted to getting my snowblower up on the second floor rather than shoveling. Then we had one of the wettest springs. I had holes drilled in my subfloor to drain the water. I easily had 10+ inches of water from all the rain. Never had one piece buckle or warp.
All 80 sheets of advantec were carried by yours truly to the second floor. It sure would have been nice to see that boom pole with the 4x8 carrier a lot sooner. Also shlepped up all my I joists in the garage by hand.
/ BARN going up
You toted 80 sheets to the 2nd floor!!!!!!!!!! Man if I ever run into you I will be very respectful..... I could not do that if I wanted to.
