Backhoe Backhoe pins and hose Q's
   / Backhoe pins and hose Q's #1
johnnylight
upstate, New York
TC34DA
I lost two pins to this date.
found one today.
any suggestions on how to keep them in place --the quick latch
keep getting knock off while am clearing, and I don't know it's missing til it's too late. **** pin $35ea at NH.
so today I replaced the quick latch with a bolt and lock nut is this ok?
My hose for my backhoe keeps getting unplug and I have the tie down straps in place. Is this how it is when clearing??
one more --blew my hose on the loader today --wow that was a loud bang
had to use TSC for parts NH and JD close at 1 pm on Saturdays.
it works fine should I replace with original parts?
   / Backhoe pins and hose Q's #2
johnnylight said:
one more --blew my hose on the loader today --wow that was a loud bang had to use TSC for parts NH and JD close at 1 pm on Saturdays.
It depends on the type of hose you bought. At a minimum it should be a 2-wire hose rated for at least 4000 psi. That is probably better than your original hose which was most likely 1-wire 2500 psi. I would also look to see why the hose blew before the relief blew, unless it was a defective hose to begin with.
   / Backhoe pins and hose Q's #3
Any pics on pin locations where you keep loosing them from?
   / Backhoe pins and hose Q's #4
I used to lose the bottom pins on the bucket. They got replaced with a bolt and nylon lock nut. Haven't had any trouble since.:D
Sorry Mad I left that part out while clearing some tree branches rub/hit /whack that hose a few times, but I did not notcie any wear so I have to check on relief valve --thanks
am just glad I didn't have a heavy load on it the way the bucket just dropped fluid spraying everywhere with a loud bang.
How can I check to see what hose I have on the backhoe?
BTDT,
the pins am refering to- go into frame (subframe)
I'll take some pictures
   / Backhoe pins and hose Q's #7
johnnylight said:
I
Did the hose blow when the quick connect became disconnected?
Instead of using nylon tiewraps on the Quick Connnects - use a hose clamp to prevent them from coming undone. They are much stronger than plastic and are re-usable.
   / Backhoe pins and hose Q's #8
You can always remove the hose and cut it to see what it's made of.
However, it should be written (screened) or molded right into the outside of the hose. If it's not then it's probably cheap generic hose.
here are some pic:
am trying to figure what the rating is you mention earlier yes it has metal inside the hose came with the BH from NH -am sure it's good.
The hose breaking was on the loader
The quick conn is on my BH poping off issue.
Do they make a hose clamp that will fit over the frame?
busy day.
am still trying to get rid of the hydralic smell from the shower today.
   / Backhoe pins and hose Q's #12
I don't know how your pin attatches on the other end, (threaded/nut, hole for lynch pin), but on larger equipment, there is a hole in the end of the strap that is welded to pin (the end showing in pic). Drill a hole for a 3/8 bolt to fit through, turn strap and mark hole in bracket/channel, drill and tap/or drill for 3/8 bolt (see attatchment), then fasten in place with bolt. Hope this works for you.
  • Pin solution.pdf
   / Backhoe pins and hose Q's #13
If you cut the hose you should see one or two layers of metal wire embedded into the hose covering. They will be very distinct.
   / Backhoe pins and hose Q's #14
If the pin is the one shown a bolt and nylon lock nut should work.
   / Backhoe pins and hose Q's #16
Did you get your pin situation situated?
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
FUTURE MB27-27" HYD MIXING BUCKET (A60432)
FUTURE MB27-27"...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
John Deere XUV825E (A61306)
John Deere XUV825E...
