Backhoe Backhoe pins and hose Q's
   / Backhoe pins and hose Q's
GuglioLS said:
Did the hose blow when the quick connect became disconnected?
Instead of using nylon tiewraps on the Quick Connnects - use a hose clamp to prevent them from coming undone. They are much stronger than plastic and are re-usable.
The hose breaking was on the loader
The quick conn is on my BH poping off issue.
Do they make a hose clamp that will fit over the frame?
busy day.
am still trying to get rid of the hydralic smell from the shower today.
   / Backhoe pins and hose Q's #12
I don't know how your pin attatches on the other end, (threaded/nut, hole for lynch pin), but on larger equipment, there is a hole in the end of the strap that is welded to pin (the end showing in pic). Drill a hole for a 3/8 bolt to fit through, turn strap and mark hole in bracket/channel, drill and tap/or drill for 3/8 bolt (see attatchment), then fasten in place with bolt. Hope this works for you.
  • Pin solution.pdf
   / Backhoe pins and hose Q's #13
johnnylight said:
am trying to figure what the rating is you mention earlier yes it has metal inside the hose came with the BH from NH -am sure it's good.
If you cut the hose you should see one or two layers of metal wire embedded into the hose covering. They will be very distinct.
   / Backhoe pins and hose Q's #14
If the pin is the one shown a bolt and nylon lock nut should work.
   / Backhoe pins and hose Q's #16
Did you get your pin situation situated?
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
More info coming soon! (A55851)
More info coming...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
