Backhoe Backhoe pins and hose Q's
   / Backhoe pins and hose Q's
GuglioLS said:
Did the hose blow when the quick connect became disconnected?
Instead of using nylon tiewraps on the Quick Connnects - use a hose clamp to prevent them from coming undone. They are much stronger than plastic and are re-usable.
The hose breaking was on the loader
The quick conn is on my BH poping off issue.
Do they make a hose clamp that will fit over the frame?
busy day.
am still trying to get rid of the hydralic smell from the shower today.
   / Backhoe pins and hose Q's #12
I don't know how your pin attatches on the other end, (threaded/nut, hole for lynch pin), but on larger equipment, there is a hole in the end of the strap that is welded to pin (the end showing in pic). Drill a hole for a 3/8 bolt to fit through, turn strap and mark hole in bracket/channel, drill and tap/or drill for 3/8 bolt (see attatchment), then fasten in place with bolt. Hope this works for you.
  • Pin solution.pdf
   / Backhoe pins and hose Q's #13
johnnylight said:
am trying to figure what the rating is you mention earlier yes it has metal inside the hose came with the BH from NH -am sure it's good.
If you cut the hose you should see one or two layers of metal wire embedded into the hose covering. They will be very distinct.
   / Backhoe pins and hose Q's #14
If the pin is the one shown a bolt and nylon lock nut should work.
   / Backhoe pins and hose Q's #16
Did you get your pin situation situated?
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2014 Audi Q5 SUV (A56859)
2014 Audi Q5 SUV...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
