Backhoe Backhoe pins and hose Q's
   / Backhoe pins and hose Q's #1
johnnylight
upstate, New York
TC34DA
I lost two pins to this date.
found one today.
any suggestions on how to keep them in place --the quick latch
keep getting knock off while am clearing, and I don't know it's missing til it's too late. **** pin $35ea at NH.
so today I replaced the quick latch with a bolt and lock nut is this ok?
My hose for my backhoe keeps getting unplug and I have the tie down straps in place. Is this how it is when clearing??
one more --blew my hose on the loader today --wow that was a loud bang
had to use TSC for parts NH and JD close at 1 pm on Saturdays.
it works fine should I replace with original parts?
   / Backhoe pins and hose Q's #2
johnnylight said:
one more --blew my hose on the loader today --wow that was a loud bang had to use TSC for parts NH and JD close at 1 pm on Saturdays.
It depends on the type of hose you bought. At a minimum it should be a 2-wire hose rated for at least 4000 psi. That is probably better than your original hose which was most likely 1-wire 2500 psi. I would also look to see why the hose blew before the relief blew, unless it was a defective hose to begin with.
   / Backhoe pins and hose Q's #3
Any pics on pin locations where you keep loosing them from?
   / Backhoe pins and hose Q's #4
I used to lose the bottom pins on the bucket. They got replaced with a bolt and nylon lock nut. Haven't had any trouble since.:D
Sorry Mad I left that part out while clearing some tree branches rub/hit /whack that hose a few times, but I did not notcie any wear so I have to check on relief valve --thanks
am just glad I didn't have a heavy load on it the way the bucket just dropped fluid spraying everywhere with a loud bang.
How can I check to see what hose I have on the backhoe?
BTDT,
the pins am refering to- go into frame (subframe)
I'll take some pictures
   / Backhoe pins and hose Q's #7
johnnylight said:
I
Did the hose blow when the quick connect became disconnected?
Instead of using nylon tiewraps on the Quick Connnects - use a hose clamp to prevent them from coming undone. They are much stronger than plastic and are re-usable.
   / Backhoe pins and hose Q's #8
You can always remove the hose and cut it to see what it's made of.
However, it should be written (screened) or molded right into the outside of the hose. If it's not then it's probably cheap generic hose.
here are some pic:
am trying to figure what the rating is you mention earlier yes it has metal inside the hose came with the BH from NH -am sure it's good.
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
1267 (A50490)
1267 (A50490)
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
100 gal Water Tank (A50515)
100 gal Water Tank...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
