dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,797
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I guess that answers my next question. I have two 3" cylinders for the swing. I was wondering whether to plumb them as single acting or double acting. Double acting has a lot more force and may be smoother, but single acting requires less flow (i.e. Faster). If swing speed is frequently an issue with these smaller hoes, then I will plumb them as dual acting cylinders. I suppose that worst case I can always go back in and plumb them single acting later if I want more swing speed.
If you are going to use two 3" cyls, they will swing your boom slower than
smaller cyls, if the geometries are the same. Slower is better here. DA cyls
will give more force, when one pushes at the same time as the other pulls,
but they will be slower as you said. Weak boom swing is a complaint for
many of these small attachments as the moment arms used to attach to is
short. 3" is quite big for swing cyls....you don't usually see them on hoes
smaller than 10'. They DO give the best of 2 worlds...lower speed and more
force. Some hoes with 2 swing cyls, go "over center" when fully swung to
either side, which is self-cushioning at these extremes.
