Backhoe Design Ideas
/ Backhoe Design Ideas #121
But still, in that configuration, the stabilizers aren't going to really stabilize much.
QUOTE]
Sure they would. Not as well as 2 independent outriggers, perhaps, but
you would likely not notice, IMO.
/ Backhoe Design Ideas #122
On my property I almost always have to level out the backhoe. You should think about using the 5th spool for a hydralic thumb and get a "power Beyond" adaptor and add a 2 spool valve for the stabilizers?
/ Backhoe Design Ideas #123
I personally think that this is a better idea. If the spool that you have already has PB the nit would be a simple matter to add another separate 2 spool valve to power the stabilizers. I cannot think of a time when you would use the stabilizers at the same time as the bh. In fact, if you already have 2 rear remotes, you could separately power the stabilizers through those and not even have to add a second valve.
Mike
It sounds like I'm back to the same two options that I started with...
1) Add valves to the system for hydraulic stabilizers
2) Design the backhoe with manual stabilizers
Anyone have any thoughts about the pros and cons of the two?
/ Backhoe Design Ideas #125
With manual stabilizers, you will have to get off and raise them to move, and put them back down for digging, . How are you going to level the manual stabilizers? With hyd stabilizers, push lever, raise , move tractor, let down, and work, actually not a real decision. Hyd all the way.
One valve will work if you put shut off valve to each cyl, and open the one you want to raise/lower.
Two electric valves will work, located downstream of the BH valve, just flip a switch.
/ Backhoe Design Ideas #126
Iplay, I think you're right about interconnected stabilizers not doing much. It might work to put a dual pilot operated check valve on each cylinder to run them off one valve. If it was me I'd use separate control valves. I run mine off the rear remotes. Not ideal but good enough for me.
I agree with JJ. Unless it's mounted on a 3ph with downforce, I can't envision a decent workflow with manual outriggers on a tractor mounted backhoe.
/ Backhoe Design Ideas #127
just an idea of how to indaipdently move the outriggers with out buying another valve. so heres my idea.
( just have the one valve for the outrigers but get a hydraulic ball valve that can switch the flow to one or the other and then you can switch the flow to 1 ciylinder and put it down were you want it and then switch the flow to the other ciylinder and put it down.;)
should work
welderboy14
The shut off valve to both sides appeals to me. I was thinking at first that I'd have to get a selector valve which costs almost as much as just buying another two spool.
Here's the thing about the shutoff... I'd need to shut off both hoses. Is that what something like this does?
If I went with a ball valve, I'd need two per side. That means I'd need to turn four valves every time I switched from one side to the other.
/ Backhoe Design Ideas #131
Why is that? Think about it....you need to shut off only one hose.
That's a total of ONE ball valve, on the down pressure work port of ONE of
the 2 outrigger cylinders. Like this one: https://www.surpluscenter.com/item.asp?UID=2009090312165965&item=9-7281-4&catname=hydraulic $23
This approach will give you almost the same functionality as 2 independent
spool valves, and it is about $15 cheaper than going with a solenoid-
activated spool valve like the HydraForce one I used for my thumb.
I don't recall what 5-spool valve you bought, but if it is a stack valve,
rather than a monoblock valve, you can likely buy one (or two) more
sections for it.
Now that I follow your suggestion and think about it I realize that if one hose is blocked then there's no circuit. Fluid going either way will be blocked.
sections for it.
My valve is a hand-me-down from another machine. It's a complete unit. I'm pretty sure there's no adding valves.
/ Backhoe Design Ideas #133
Why didn't I think of that? I'd still put in 2 valves, put the legs down, then close the valve on the high side for final leveling. With just one valve, you could still go up or down with the open leg to level.
I'm thinking put the two ball valves in and leave them open most of the time. In the rare instance that I need the stabilizers to work independently or if I notice some sway due to fluid running between cylinders, I can close one or both valves.
Done. $50.
Just for the record, I bought a bunch of the steel a month or so ago. I keep wanting to start cutting and welding, but I'm afraid to start until I get the whole design drawn up. I suppose that's good. Even the stuff that I thought was done and never going to change has changed a little as I make adjustments to the rest of the design. There's going to come a time, though, when I have to just start fabricating and figure the rest out as I go.
I've learned my lesson about keeping only one copy of my plan. Now I'm e-mailing the plan back and forth from work to home. I have copies on both computers plus all the email servers and cyber stuff out on the net.
/ Backhoe Design Ideas #135
I answered one question last night. That is the question of whether to go with a PTO pump or use the tractor hydraulics. I picked up a used pump and reservior from a guy on Craig's List. (Have I mentioned that I love Craig's List?).
The guy had the pump left over after he retrofitted a 3 pt. backhoe to run off of his tractor hydraulics. Judging from the size of the cylinders on this guy's backhoe, I may have a little more flow than needed. Another indication is that the reservior is pretty large... over 11 gallons. I have some larger cylinders, and I may go back to the drawing board with the larger cylinders. The next step is to mock up a simple hydraulic circuit with this pump and time the motion on some cylinders. That will tell me empirically what kind of results I'll get.
/ Backhoe Design Ideas #137
An over-sized pump is no big deal, you just slow the engine down to the volume you need. The other way to get the GPM's you need to the cylinders is to use a flow divider. It will split the volume 50/50, 70/30. or whatever divider you can find.
I've known that the tractor's hydraulics would be marginal at best. I like the idea of being able to run at a slower speed when needed or increase the throttle when I want more speed.
My only concern with the larger pump is that the tractor may not have enough power to run it. Keep in mind I only have 15 hp at the PTO. I know it will run it fine with no load, but when I put a good heavy load on it, will it kill the tractor before it can build enough pressure to do the work?
/ Backhoe Design Ideas #139
Although I don't know the cu in of the pump, A large pump will only draw the power it needs to operate. As soon as the pump is turning, it has potential pressure, and if the pump is running at low volume, 2 or 4 GPM's, it still is going to get the work done. The larger pump only becomes a problem, when it is running at full rpm, and you put a heavy load on the system, then the pump may stall the engine, because it now requires more HP, which you don't have. Once you know what that limit is, you can operate within set parameters.
It seems to me that a large pump is like running your car in a higher gear. It goes a lot faster, but can't do it if there's much of a load. The inverse is also true that a small pump is like driving around all day in 2nd gear.
There is an up side to the limitations of a larger pump... the engine will stall before the machine will tear itself to bits. It's all academic speculation for now until I can hook her up and get some real data.
Would the flow divider you suggested get around the issue of stalling the engine at full RPM?
Landhonor Plasma Cutter (A66408)
Landhonor Plasma...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
SHOPBUILT S/A TRAILER FRAME (A64278)
SHOPBUILT S/A...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
