B7800 with MMM....thoughts?
/ B7800 with MMM....thoughts? #1
Truklaw
Loomis, CA
kubota B7800
New user here.....in the market for a CUT (30hp or so) for use on my 5 acre parcel. Will use it a lot preliminarily for mowing but have grand plans for an orchard and vineyard some day. (who knows when!)
Have been checking the local area and have found B7800's with a Kubota FEL and 5' rear mower deck at no less than about $18,500 new.
Just talked to another dealer and he has a new B7800 that was just returned with 59 hrs on it. The first owner was 6'8" tall and could not fit in it well.
It has a MMM and I am wondering what the pros and cons are here (vs a mower attached to the 3PT). Are MMM's hard to remove and put back on? (should I need to) Are there brackets that remain that reduce the clearance of the 7800? How much?
They are asking $15,850 for it(also has Kubota FEL and all new product warranties). I find this very enticing.
Thoughts? /forums/images/graemlins/confused.gif
/ B7800 with MMM....thoughts? #2
A B7800 with 72" MMM and 420 FEL would run at least $17000 plus tax around here. If I was buying a tractor and came across a deal like that it would be my tractor. You may want to make sure the 50 hours service has been completed. If it has not been done as the dealer to include it.
I have a B2910 (same tractor more features) with 72"MMM it is a great mowing machine and does a lot of other projects. I can mow my 2 acre lawn in less than 1 hour.
/ B7800 with MMM....thoughts? #3
That's a good price on the used B7800 w/mmm and 402 FEL. The remainder of the warranty is transferable to the new owner, so it's like a new tractor. I agree with Ron, get the dealer to do the 50 hr maintence as part of the deal and grab it if in good shape.
/ B7800 with MMM....thoughts? #4
Forgot! /forums/images/graemlins/blush.gif
Welcome you to TBN. /forums/images/graemlins/smile.gif
/ B7800 with MMM....thoughts? #5
Sounds like a pretty good savings... You figure if the dealer is asking 15800, and they have to be making at least 1000-1500 on that tractor , the poor guy who traded it in must have lost around 3500 dollars... Oh well, his loss is your gain...
/ B7800 with MMM....thoughts? #6
Talk about De Ja Vu.... Wasnt this subject just talked bout yesterday in another post...
/ B7800 with MMM....thoughts? #7
Sounds like a decent deal. The mid-mount mower is a bit more difficult to take on and off but it isn't that big of a deal. The B7800 linkage does hang down a little, but you can raise it up and lock it entirely out of the way. (The instructions are in the manual on how to do this). One thing for sure is that you don't want to do any loader work or anything else where clearance is an issue. It could do considerable damage to an expensive mowing deck as well as hanging you up. I have used both RFM and MMM decks and I prefer the RFM, but not strongly so. Others prefer the MMM and I suspect a lot of it has to do with your application. I would not dwell on it much as far as purchasing this unit. Good luck!
/ B7800 with MMM....thoughts? #8
</font><font color="blue" class="small">( Are MMM's hard to remove and put back on? (should I need to) )</font>
Piece of cake - takes me 5 - 7 minutes to remove or install the 72" MMM on my B2910. Taking the FEL on or off is another 5 minutes or so. And it seems like it keeps getting faster each time I do it. /forums/images/graemlins/grin.gif
Like was said, the linkage (and or the MMM deck itself) can be pinned up in the top position, out of the way. You can get away with doing a limited amount of FEL work with the MMM on, on fairly level terrain.
/ B7800 with MMM....thoughts? #9
I don't know about other MMM's. But the 72" MMM for the B27-2910 & B7800 tractors is one of the easiest mowers to remove. There is one requirement. There must be a hard flat area large enough to move mower out from under tractor. It is then as easy to install and remove as the easiest 3PH attachment. This mower weighs about 500 lbs.
/ B7800 with MMM....thoughts? #10
I would not hesitate on the B7800 with MMM. I am a fairly new owner of a B2910 with 72" MMM and 402 loader and it has cut my mowing time in half compared to my Mitsubishi gear drive with 60" mower. It has also been a joy to use to finish up a great many tasks around the property. I have alot of smaller trees to mow around and the MMM allows me to mow around each of them alot closer than I think a RFM would. I think it is what you are used to, but for me the MMM is much easier to use and more efficient when mowing up close to things. One comment on the RFM is the ease of backing up to areas with the RFM which cannot be done with the MMM.
The one negative comment I have with any compact is the ROPS when mowing around smaller trees. It gets kinda annoying to moving branches away from the ROPS when you are mowing close to trees. At least with the B2910 you can lower the ROPS when mowing. Not sure if the B7800 has that option? A foldable ROPS would be one thing to consider when purchasing. Maybe you could get a replacement at a good price if not.
/ B7800 with MMM....thoughts? #11
I have a new B7800 (5 Hrs) and a 72"RMM rear discharge. I like the rear discharge because it spreads the discharged grass clippings over a wider area than a side discharge, so rows or bunches of grass clippings are less noticable and they disappear faster. However, the B7800 with RMM takes up alot of room in my garage. If Kubota had a rear discharge MMM I'd have one, so that I could gain more garage space.
/ B7800 with MMM....thoughts? #12
What tires do you all have on the 7800 for mowing? More specifically I was wondering if ag tires would cause *excessive* tearing up of the lawn.
I'm not too fussy about the lawn, right now I often don't take the tire chains off my lawn tractor in the spring. I ask simply because I just wouldn't want to see 12 inch chunks of sod getting thrown around unnecessarily.
Have a large number of wooded acres and about 2 acres of lawn & a bit of garden. If (when) I get my 7800, what are your thoughts on tires?
Thanks
/ B7800 with MMM....thoughts? #13
I had turfs on mine but had the dealer switch them to R4's after mowing my yard once. If the grass is wet the traction was bad on my hilly piece of paradise with turf tires. The R4's do much better but will cut up the yard a little in 4 wheel drive when making tight turns. I think the Ag's would be harder on the lawn.
/ B7800 with MMM....thoughts? #14
<font color="red"> What tires do you all have on the 7800 for mowing? More specifically I was wondering if ag tires would cause *excessive* tearing up of the lawn. </font>
I would suggest R4's over R1's if you're mowing a lawn.
I've got R4's (not loaded) on the B7800 and most of the time I can mow in 2wd, on some hilly areas I'd break traction and have to switch to 4wd. I do notice some scuffing on the grass from the front tires if I turn to sharp in 4wd.
I use to mow the same area with my Ford 2000 (2wd) with R1s on back. The R1's did leave noticable imprints in soft areas and some hilly areas, but then the Ford 2000 is a heavier tractor, plus the tires were loaded but I never lost any traction while mowing.
For me the R4's are a better choice than R1's because all I plan to use this tractor for is mowing, snowblowing, and some grading in my gravel driveway. I've tried the mowing and the grading and if I thought I needed more traction I just put it in 4wd. I haven't tried snowblowing but plan to use tire chains on the rear R4's and 4wd if I need to.
/ B7800 with MMM....thoughts? #15
Personally I hate MMM's. Lining them up, pushing/pulling them under the tractor, crawling underneath to hook up the PTO. You spend alot of time on your back and knees. Getting to all the grease points is also a major pain.
I'd much rather back up, connect the 3 points, PTO and away I go.
Gentlemen,
Well, I did it. On Friday the B7800 will be delivered. And not a moment too soon. The weeds and grass have been piling up since the 3 yo Craftsman 23hp rider gave up with a loud bang, a hole in the engine block and a puff of smoke.
My bride has resigned herself to the fact that I will be of a singular focus for a few days. I lobbied and told her that my "Kubota Obsession" will result in a more beautiful property. She gave me that look you got from your teacher when you told her the dog ate your homework. /forums/images/graemlins/grin.gif
I am pumped and will post pics when I can dismount long enough to grab the camera.
KT
/ B7800 with MMM....thoughts? #17
Congrat's on your purchase. /forums/images/graemlins/smile.gif
It should not take long to catch up on your lawn cutting. /forums/images/graemlins/cool.gif
Then your wife can start clicking off the items on her list. /forums/images/graemlins/tongue.gif
/ B7800 with MMM....thoughts? #18
thanks for the advice on the tires guys. I'll make do with the lawn tractor for another summer as I soften up the battlefield with my wife. Every chance I get I mention how her life will be enriched by ME having a big orange tractor. Luckily my neighbor just bought a Kubota so I can point out all the great projects he does for HIS wife.
Won't be long now.
/ B7800 with MMM....thoughts? #19
Here is a secret I have found on my B2910.
I have the RCK60-27b MMM.
If you roll the bucket on the FEL all the way down and put a plank under it.
You can lift the front wheels off the cement floor about 9 or 10 inches.
This allows you to roll the deck straight out under the front wheels.
The deck will fit between the front wheels and the bucket.
It takes 2 minutes to drop the deck..
Another 5 to put it back on ( Drive shaft alignment)...
Regards,
Chris
/ B7800 with MMM....thoughts? #20
Truklaw,
I have turfs on my B2910 and they are loaded in the rear..
I have some hilly areas and almost never have to put it in 4wd.
I plow snow with the turfs and they work just fine...
Taking them into the woods is a little dicey though...
Good luck with the new machine....
Your going to love this machine... It's even better than Tivo!
Regards,
Chris
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
