Another Trailer Thread
/ Another Trailer Thread #21
If you go new consider a tilt or partial tilt. Here is my 20' that is 16' tilt and 4' in front stationary. Trailer deck is 20' over all not including the great dovetail.
I went 22' partial tilt and love the trailer...always hated messing with ramps and the 6' stationary deck allows placement of extras.
Also relative to the complexity of "rules" for towing trailers in your area consider putting 7000lbs axles under the trailer giving one plenty of strength and room to grow 'should' your loads grow
Lots of choices which is great
/ Another Trailer Thread #22
I am like you, I went with a 16K 20' + 4' tilt bed. The 4' stationary is big enough for my needs and I really like the low bed tilt. easy to load anthing including my wife's Can-Am - Spyder 3 wheel motorcycle.
The Gator has a much stronger gooseneck made out of 12" "I" beams and the frame is all 6" square tube.
It's a beast that's easy to handle.
/ Another Trailer Thread #23
To get more load capacity you will need to get out of the 15" tires and get into a 16" tire. I would be inclined to look at the 14k capacity trailers, they are plentiful and often in the same price range as the 10k trailers or atleast in south Texas they are. Have you thought about having a rack built on the front of the trailer tongue to rest the FEL on in the upright position and high enough to clear your camper top? I have a 20' Gooseneck that I haul my 54hp case on with a 7' brush hog and do basically the same thing. The FEL rests on the GN part, tires to the front and I have minimum over hang on the rear with brush hog and disc. As far as tire height, you can get low profile 16" LR E tires to keep the trailer bed height down. I did this on one trailer I had at one time that I used a cattle insert on to haul cattle.
/ Another Trailer Thread #24
I see you are in Wyoming. I suggest keeping the 18' trailer and then buying a new 24'. There is a reputable PJ trailer in Scottsbluff, Ne (Ryans welding & trailer sales) that we have a new 24' on order through right now.
Thanks but that would be a 1100 mile round trip taking 16 hrs according to mapquest.
I will be in Idaho this weekend and plan on spending some time looking at new trailers.
About 3 weeks ago I went and bought a new trailer. I have been pretty busy since so I didn't post anything about it but here is a quick picture I took of it at the dealers place.
I had heard of the Iron Bull Trailers but hadn't seen one before this one. Apparently they recently got into building the car/equipment hauler type trailers. The dealer had both PJ and Iron Bull trailers so I was able to directly compare the two. From my understanding, PJ trailers are one of the better trailers but after comparing it to the one I bought I feel the Iron Bull is a little better trailer.
It is a 14k 7'x20' with a dovetail. 4 bolts hold on the fenders so they are easy to remove if necessary. It includes stake pockets, rub rails, pipe spools and D-rings for tying down loads. The 10k jack is bolted to the front of the deck but can be moved towards the front of the tongue easily if I decide to install my winch at the front of the deck. Plus I chose to get the slide in ramps rather than the fold down ones for my purposes.
The dealer spent quite a bit of time showing me how the PJ and Iron Bull compare and made me a good price so I pulled the trigger. Maybe this weekend I will get a chance to load the tractor on it.
I finally had a chance to use the trailer. We needed the weeds mowed around the shop so I brought in the tractor with mower to get it done.
It hauled like a dream on that length trailer. It would be easy to forget the trailer and load was even back there.
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2007 Toyota Rav4 (A64557)
2007 Toyota Rav4...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
