Another Trailer Thread
/ Another Trailer Thread #1
Reb954
20 miles from somewhere.
Mahindra 2565
I have been looking for a 10K, 7'x20' car hauler trailer to replace my 7K, 7'x18' car hauler. My current needs require hauling more weight than the old trailer would handle safely. It seems there aren't a lot of these trailers around, at least not used ones. I did run across one, price was right so the owner said he would drop it off so I could try it out to make sure it fit my needs. When he showed up though it was only 18' long but I thought I would give it a try.
As you can see, I tried loading it a couple different ways. I can make it work but I am going to hold out for a 20' trailer. May even just buy a new one.
/ Another Trailer Thread #2
I would go 22 or 24 feet ,Your setup is pretty long
/ Another Trailer Thread #3
Definitely go longer. I would try backing it on that trailer and seeing how it rode. The new fords have stout hitches. On my 450 it was rated for like 20-22k on the bumper
Brett
/ Another Trailer Thread #4
That trailer looks more like an equipment trailer than a car hauler.
In my opinion, buying a new trailer is the best idea.
You get new decking, new wheel bearings, new brakes, and new tires.
Wiring, coupler, breakaway chains & battery, tongue jack, and everything else is new.
You should specify 16" wheels also.
I bought 20', but should have bought at least 22'.
I'm resisting going longer than 20' due to using the same trailer to haul my camper and ATV into the mountains, the longer it gets the fewer places I can get into.
This picture has my previous pickup in it.
I measured it out for backing the tractor on but that will leave quite a bit of open deck in the front of the trailer and leave the bucket hanging quite a ways out the back. The center of weight is just in front of the back tire and what appeared to give the best tongue weight was with the front of the rear rim centered over the center of the axles. I didn't pull it to confirm but I know it won't vary much from that.
/ Another Trailer Thread #7
If you get a 20 foot trailer look at big tex mega ramp or something the same, That way u have a flat deck to load on . what's the total length of your tractor and attachments
The trailer manufacturer's web site calls it a car hauler so that is what I will call it.
I will probably end up with a new one. I'm just not finding many in a 100 mile radius of here. This one was about 150 miles away. The owner was passing thru here so he dropped it off but he will pick it up on his way back. I found another one 120 miles the other way but the guy wanted new price for a 2 year old trailer.
The 15" wheels are fine for me, I want to keep the height down some for loading the camper.
/ Another Trailer Thread #9
How about keeping the one you have for camper use, and buying a dedicated equipment trailer for your tractor needs?
That's the direction I'm going. I have an 18' car trailer that is too short and too light duty for my tractor needs. I plan to keep it to actually haul cars and light duty stuff, and looking into 26-28' deckover goosenecks for my tractoring needs. Then I don't have to worry about the high approach angles on a deckover for trying to load cars, and have a large enough deck I can load my tractor with brush hog and FEL, plus have room for another implement or 2 in front.
/ Another Trailer Thread #10
Not exactly. You can pin the ramps upright and still utilize that space. You can lift the FEL up and drive all the way forward, flip the ramps down, and then backup. You can't load a 23 foot long pickup on my 20ft deck trailer and then flip the ramps down level. You can pun the ramps upright and still haul the 23ft long pickup. This is coming from a satisfied big tex mega ramp owner. Although mine is a GN deck over.
/ Another Trailer Thread #11
I don't think he's loading a 23 foot pickup looks like a tractor with attachments
/ Another Trailer Thread #12
Go longer than 20... it looks like if you don't, you are still going to be stretching your limits. Having to disconnect a bucket to fit it on the trailer will get real old real fast. .. on another note.. I'm surprised how well your 250 takes the young weight of that.. I have a 350 and the trailer weight alone is noticeable when it's hooked up.. I'm going to have to get air bags this spring.
/ Another Trailer Thread #13
I bought this all aluminum 20ft car hauler last summer. As you can see it fits my l3301 very nicely. We move a bunch of stuff around from my son's house to me to our cabin, and this seemed a good fit. That's his F 350 hooked up, but I like it because I can use my 150 as well. We use the dump trailer to haul the mx tractor and mini excavator.
Length as shown with the bucket on is right at 20 feet. With my mower in place of the blower it will be about 2 feet longer.
/ Another Trailer Thread #15
The mega ramp might work then the deck will be flat to load your camper or the mower will sit flat on the trailer . If you can pull up far enough to fold the ramps down. I have slide in ramps on one of my trailers sometimes fold up ramps get in the way
/ Another Trailer Thread #16
Do get the air bags, you will love them.
The Loadlifter 5000 ultimate bags are relatively easy to install.
/ Another Trailer Thread #17
If you go new consider a tilt or partial tilt. Here is my 20' that is 16' tilt and 4' in front stationary. Trailer deck is 20' over all not including the great dovetail.
That pickup does handle weight well. Even with a couple thousand pounds in the back and 4 people in the front I only had to adjust the headlights down 1 turn.
Something else I found with that pickup, due to my background my tendency has always been to tie down loads securely, this pickup reaffirmed one of the reasons for doing that. It could easily walk out from under a load.
That is a nice looking trailer. I'm not sure how a tilt trailer will work loading my camper but I will check into it next time I am someplace where they sell them.
Suggestion for you, run your chain thru the stake pocket and hook it underneath the trailer frame if possible. It is a lot stronger hook up that way and less chance of tearing or distorting a stake pocket.
/ Another Trailer Thread #20
Yep... I went 22' so I could do a lot of moving around with stuff. You'd be better if you had some room to center your load not just be satisfied with getting it on there.
2005 Little Wonder High Output Walk-Behind Blower (A64553)
2005 Little Wonder...
2021 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A64556)
2021 Ram 1500...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
