Air Compressors??
/ Air Compressors?? #21
I went with 6.5 hp gasoline engine twin tanks low profile (the pump has two cylinders)
My fields are spread out and it sure is nice to have it on the service truck ..
Kinda Heavy so I use the pallet forks if and when i have to offload it ... which is very seldom.
Not saying thats an option just works for me ...
/ Air Compressors?? #22
Someday, I would love to have a 220V "real" compressor for my shop.
But, for the past 40 years I have lived with various cheap 120V air compressors and I have never really felt compressor deprived. Every couple of years I have to take a tire & rim off a vehicle, but my IR air impact does that if I wait a few minutes between lug nuts. When I put it back on I use anti-seize and torque the lug nut so I can get it off by the side of the road in a rainstorm if that situation arises -- don't need an impact wrench for that, and in fact you don't want one.
A great big air compressor sure would be nice to have, but I just got a Rigid from Home Depot for ~$250 that will power two nail guns at once and is light enough to carry to the job.
/ Air Compressors?? #23
I bought a five hp Quincy compressor back when I built my shop. They are pricey but work tremendously well. I have a pancake style oil less I bought for roofing and mobile projects. Both do the job intended. I love the five hp models they sell for 600. The motor is the size of a 3/4 hp standard motor... yet its 5 hp? I understand there is a couple law suits going on reference this advertising.
/ Air Compressors?? #24
Yep I have one of them "5 HP" motors on my chintzy little Campbell Hausfeld oil less compressor. :laughing: If you look it up, I think about 2 HP is the biggest motor you can run on a standard 117V outlet before the breaker trips. And a real 5HP motor is pretty good sized and needs 240V. I dont know where they get their motor sizing ruler, but it would make a good addition to most anglers tacklebox:laughing:
/ Air Compressors?? #25
it's all in how you measure it.
It likey says 'peak' hp....
be kinda like saying your wall outlet was 340vac Peak to peak.. or 170vac peak.. or.. what we all see.. 120vac RMS ( root mean square )
soundguy
/ Air Compressors?? #26
Of course, as a teenager, I worked in my Dad's service stations where we had big air-compressors, but I don't even remember the brand or size of either of them. But after I was grown, married, and a home owner, I think I started with a 7 gallon, then up to a 12 gallon, then a 20 gallon compressor for home use in town. When we sold the house and became full time RVers, I carried a little 2 gallon DeVilbiss oilless, 1/2 hp compressor (my first oilless). When we first bought the place in the country, I made the mistake of buying one of those Craftsman, 30 gallon horizontal, 4.5 hp, oilless compressors by DeVilbiss. But since I use a compressor so much, it had to be rebuilt every 6 to 8 months, so I finally bought a 60 gallon vertical, V-twin, 230 volt, 6 hp Puma compressor for my shop. Of course that 4.5 hp in the Craftsman and the 6 hp in the Puma were the old phony ratings. The dealer from whom I bought the Puma even told me they called it an "imitation" 6 hp and showed me one of their true 5 hp compressors (much bigger motor, of course). When we sold the farm and moved back to town, temporarily in an apartment, I bought one of the little Craftsman 3 gallon, direct drive, oiled compressors.
ALL of those compressors went to a maximum pressure of 120-125 psi. But 5 years ago, when I bought this house, I bought an Industrial Air (by Powermate) 30 gallon verticle twin, 120 volt (can be converted to 230) with a 1.8 "running" hp motor with a working pressure of 125 to 155 psi. It's amazing how much different that addtional 25 psi makes when using the blow guns, which is the majority of my use now. I do have a 3/8" ratchet, a 1/2" impact, a one qt. paint gun, a siphon gun, and an angle die grinder, but the 4', 2', and very short blow guns are used regularly.
/ Air Compressors?? #27
look at that extra PSI at that volume.. lotsa air power there!
soundguy
/ Air Compressors?? #29
I have a 60 gallon 5 HP Sanborn single stage that just died. There was a pinhole by the drain valve on the bottom of tank that I welded about 5 years ago. I made the decision not to put any money in a 25 year old compressor so I just ordered a 60 gallon 5 HP Quincy two stage. Have wanted a two stage for years anyway. Looking forward to trying it out! I have a small twin tank Central Pneumatic that I use for nail guns and to pump up the odd tire etc. It was a cheap compressor but it has help up amazingly well.
/ Air Compressors?? #30
There is a simple way to tell if it is actually a 5 hp motor. At 230 volts, it will draw 20, or more amps, at full load.
This is why a "real" 5 hp, or larger, compressor requires a magnetic starter.
If it does not have one of these: Square D 8536SCG2V03 Magnetic Motor Starter, it's a pretend 5 hp.
When you look at the better 2 stage compressors, in HD, or Sam's Club, etc, they come with a mag starter prewired, and hung on the unit.
Lawn mower engine makers have been engaging in the same baloney.
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
2008 Kubota M125X (A60462)
2008 Kubota M125X...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
206320 (A57192)
206320 (A57192)
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
40' High Cube Multi Door Shipping Container (A60463)
40' High Cube...
