Failed to find check valve now looking for another A. Compressor
   / Failed to find check valve now looking for another A. Compressor
Either is perfectly acceptable. If you don't want to see armored running down your wall, you could also mount a box up above and transition from armored to EMT at that box. If it's a short run of EMT just down the wall, you could even do it without a splice, just strip the armor off the last several feet, and leave a service loop in the box in case you ever want or need to cut and splice later.
I have armored running thru the rafters in my own barn, for most of the lighting, but only ever use EMT when running on the wall in a finished shop space.
Make sure you know which cable clamps to use with armored cable, they're not the same as NM-B (Romex) clamps, and make sure you know how to terminate the sheathing so it won't chafe the wiring. But there's nothing wrong with armor, other than cosmetics.
Got it TY...!
   / Failed to find check valve now looking for another A. Compressor #32
Just don’t be Thomas:
lotta truth ...... which is why I got a licensed sparky to run my 50 amp welding circuit.
I've been out of the game for ten plus years.
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2025 DORSEY ALUMINUM FLATBED TRAILER (A59575)
2025 DORSEY...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
3650 (A47477)
3650 (A47477)
