Failed to find check valve now looking for another A. Compressor
   / Failed to find check valve now looking for another A. Compressor
Either is perfectly acceptable. If you don't want to see armored running down your wall, you could also mount a box up above and transition from armored to EMT at that box. If it's a short run of EMT just down the wall, you could even do it without a splice, just strip the armor off the last several feet, and leave a service loop in the box in case you ever want or need to cut and splice later.
I have armored running thru the rafters in my own barn, for most of the lighting, but only ever use EMT when running on the wall in a finished shop space.
Make sure you know which cable clamps to use with armored cable, they're not the same as NM-B (Romex) clamps, and make sure you know how to terminate the sheathing so it won't chafe the wiring. But there's nothing wrong with armor, other than cosmetics.
Got it TY...!
   / Failed to find check valve now looking for another A. Compressor #32
Just don’t be Thomas:
lotta truth ...... which is why I got a licensed sparky to run my 50 amp welding circuit.
I've been out of the game for ten plus years.
2015 CAT D5K2 LGP (A55272)
2015 CAT D5K2 LGP...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
PALLET OF FISHING GEAR (A58374)
PALLET OF FISHING...
2021 Honda Pioneer 4x4 Utility Cart (A56857)
2021 Honda Pioneer...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
