rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,952
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Having 4wd sure does help a tractor with a load in the FEL bucket to turn in muddy fields. A 2wd with skinny ribbed tires up front will sometimes try to just plow mud instead of turning... The trick is to use the individual rear wheel brakes to help it turn - makes it much easier. Individual braking does take some practice, but anyone can learn how. Also, having well adjusted powerful and sensitive rear wheel brakes is an advantage. My favorites are the the countershaft-mounted internal "wet brakes" common to most utility type and larger tractors. .
