Adding onto a trailer lenth
/ Adding onto a trailer lenth #61
I allways weld the inside and then grind with a thick deburr disk into the joint on the outside till the back of the inside weld is smooth, then fill the U youve cut with another weld. That guarantees full penetration. My workshop girders are made of several leftovers. Welds are stiffer and therefor have a lower fatigue limit, but a good penetrated weld that is ground smooth on the surface, is as strong as the base material in static loading.
/ Adding onto a trailer lenth #63
Mild steel has a tensile strength of just over 60klbs. The first 2 numbers on welding rod is the tensile strength in klbs. 60 & 70 are the most common, 80 isn't uncommon.
So a properly done weld with full penetration can easily be stronger than the base metal. Add on top of that welds are usually thicker than the base metal & are splinted you get something significantly stronger. Skill varies & you don't always get full penetration so it can be weaker if not done right.
/ Adding onto a trailer lenth #64
I added about 32" to my eq. trailer.
Nice! How far back did you move the axles?.
/ Adding onto a trailer lenth #66
I didn't move the axles because they were already way back. That was one of my problems, I had too much hitch weight.
Lucky if I put on the 4' I will have to move them
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
Rear Axle For Case IH 2388 Combine (A65640)
Rear Axle For Case...
Landhero Electric Hoist (A66408)
Landhero Electric...
Landhonor Quick Attach Tree Puller (A66285)
Landhonor Quick...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A65563)
2007 Isuzu FTR...
2007 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2007 MACK GRANITE...
