Adding onto a trailer lenth
/ Adding onto a trailer lenth #61
I allways weld the inside and then grind with a thick deburr disk into the joint on the outside till the back of the inside weld is smooth, then fill the U youve cut with another weld. That guarantees full penetration. My workshop girders are made of several leftovers. Welds are stiffer and therefor have a lower fatigue limit, but a good penetrated weld that is ground smooth on the surface, is as strong as the base material in static loading.
/ Adding onto a trailer lenth #63
Mild steel has a tensile strength of just over 60klbs. The first 2 numbers on welding rod is the tensile strength in klbs. 60 & 70 are the most common, 80 isn't uncommon.
So a properly done weld with full penetration can easily be stronger than the base metal. Add on top of that welds are usually thicker than the base metal & are splinted you get something significantly stronger. Skill varies & you don't always get full penetration so it can be weaker if not done right.
/ Adding onto a trailer lenth #64
I added about 32" to my eq. trailer.
Nice! How far back did you move the axles?.
/ Adding onto a trailer lenth #66
I didn't move the axles because they were already way back. That was one of my problems, I had too much hitch weight.
Lucky if I put on the 4' I will have to move them
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
New/Unused ATS EPC40 Plasma Cutter (A65583)
New/Unused ATS...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
40in. Skid Steer Tree Spade (A65640)
40in. Skid Steer...
