Adding onto a trailer lenth
/ Adding onto a trailer lenth #61
I allways weld the inside and then grind with a thick deburr disk into the joint on the outside till the back of the inside weld is smooth, then fill the U youve cut with another weld. That guarantees full penetration. My workshop girders are made of several leftovers. Welds are stiffer and therefor have a lower fatigue limit, but a good penetrated weld that is ground smooth on the surface, is as strong as the base material in static loading.
/ Adding onto a trailer lenth #63
Mild steel has a tensile strength of just over 60klbs. The first 2 numbers on welding rod is the tensile strength in klbs. 60 & 70 are the most common, 80 isn't uncommon.
So a properly done weld with full penetration can easily be stronger than the base metal. Add on top of that welds are usually thicker than the base metal & are splinted you get something significantly stronger. Skill varies & you don't always get full penetration so it can be weaker if not done right.
/ Adding onto a trailer lenth #64
I added about 32" to my eq. trailer.
Nice! How far back did you move the axles?.
/ Adding onto a trailer lenth #66
I didn't move the axles because they were already way back. That was one of my problems, I had too much hitch weight.
Lucky if I put on the 4' I will have to move them
John Deere RM 12R Cultivator (A66285)
John Deere RM 12R...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
