Add Oil ?
/ Add Oil ? #1
Dog Gone It
TN.
L2501 (4wd)
Just bought a used JD F932. Im going though it the best I can. I have checked all oil levels and added. I have one that I dont know what to add and cant find any info on line. I really need a manual bad !
Anyway there is an Oil Cap just like the engine oil cap located at the front of the motor block just behind the cooling fan. Do I add reg motor oil or heavy weight and how far do I fill it to ?
Thanks
/ Add Oil ? #2
You'll want a technical manual. TM1487
Is the cap you're posting about on a square plastic tank? If so that's the transmission fluid overflow tank. Add transmission fluid there.
/ Add Oil ?
No the cap is exactly the same as the oil cap on the valve cover and its located on a metal housing that looks similar to a large water pump housing and this housing is attached directly to the front of the engine block. Im beginning to think that its nothing more than another access to pour oil into the engine but Im not sure why.
Thanks
Two (2) John Deere 4000-Series Tractor Grill Guards (A65640)
Two (2) John Deere...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2019 JOHN DEERE 325G SKID STEER (A65053)
2019 JOHN DEERE...
2017 Subaru Forrester (A62613)
2017 Subaru...
