Add Oil ?
/ Add Oil ? #1
Dog Gone It
TN.
L2501 (4wd)
Just bought a used JD F932. Im going though it the best I can. I have checked all oil levels and added. I have one that I dont know what to add and cant find any info on line. I really need a manual bad !
Anyway there is an Oil Cap just like the engine oil cap located at the front of the motor block just behind the cooling fan. Do I add reg motor oil or heavy weight and how far do I fill it to ?
Thanks
/ Add Oil ? #2
You'll want a technical manual. TM1487
Is the cap you're posting about on a square plastic tank? If so that's the transmission fluid overflow tank. Add transmission fluid there.
/ Add Oil ?
No the cap is exactly the same as the oil cap on the valve cover and its located on a metal housing that looks similar to a large water pump housing and this housing is attached directly to the front of the engine block. Im beginning to think that its nothing more than another access to pour oil into the engine but Im not sure why.
Thanks
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
Friesen 240 Seed Tender (A63116)
Friesen 240 Seed...
2016 John Deer 5075E (A60462)
2016 John Deer...
